Nothing big, did that and have the t-shirt. Anyway, I decided to upgrade the fronts with Image Dynamics XS69's that I had lying around. Don't need the passives so ditched those. Of course, the sound was immediately noticeable with muddy sound gone. Up front bass more accurate and articulate then before. I have the Fader more to the front. Not a big fan of music coming from behind me. I want it out front and WIDE. I did put a couple layers of Dynamat behind the speakers and Covered the 6x9 shell with Dynamat as well.
So then, I took out the factory subwoofer. Decided to go ahead and reuse box, not spending "Stupid" money for the Stealthbox.....way overpriced. Anyway, sealed the box using bedliner spray with about 5 coats. CAN YOU SAY HEAVY. I then covered that with acoustic spray. Bought the JL 8W3v3 4 ohm. Due to the depth, I had to make MDF ring to raise the woofer up. I sealed the back hole with some MDF and liquid nails before sprayed...same with rubber grommet for the wiring harness. I did spray the quarter panel with acoustic spray and layered some dynamat behind the Sub enclosure. Good way to test the seal is pushing the woofer in....should return fairly slow.
The sound was immediately noticed, with really deep lows playing "The Joint" on Sirius. Went ahead and through in some Dire Straits and Dark side of the Moon. Very very happy. It images better then factory but not quite centered. Drums roll across the dash....left to right or right to left...wider than I expected which is great.
All in all, I may have $200 wrapped in it with the Sub and misc stuff....
