1 - 9 of 9 Posts
I was wondering what audio system you guys have and how do you have them set.
I have
Stock My Gig/Nav with the Boston speakers
Base 2
Mid 4
Treb 6
Vol usually on 20-26
(IMO my Boston rear speakers sound like chit) I'm looking for an upgrade plug & play that can handle the lows better.
Factory RAQ unit - aftermarket amp, speakers, sub woofer
Bass: 0
Mid: -1
Treb: 2
Balance: L+1
Fade: Can't fade due to amp connectivity, but I'm usually faded to the front almost entirely.
Volume: 15-20 units (aftermarket amp makes this number irrelevant to comparisons)
2005 Grand Cherokee
Stock 6 disc cd changer.
Bass - 0
Mid - 2
Treb - 3
Sub/w adjusted by my mood.
Fad =
Bal =
Normal volume is 12-15 when alone in jeep.
A Real Jeep
I have: The Stock RES Radio
Bass: 0 (Subs take care of this)
Treble: 9
Midrange: 9
Balance: 0
Fader: 0
Normal Volume: Anywhere from 0-Max... depending on mood, type of music and whether the windows are down or not.
I have the REF head unit w/BA sound system.
Treble- +7
Mid- +1
Bass- -2
Fade- 0
Bal- 0
I just turn up the bass boost on my sub which minimizes distortion of the other speakers. Especially the full range rear door speakers. The highest I turn the volume is 25 to 30.
I have the REC nav with the Boston Acoustics sound system, also two RF punch 12's getting about 250W RMS each.
Bass: -1
Mid: 7
Treble: 9
Balance:0
Fade: R1
I have the gain on my amp set in the middle, bass boost on the amp all the way up, low pass filter is off. I usually listen to my music with the volume between 8 and 15 and it sounds pretty damn good for a stock audio system with two 12's.
1 - 9 of 9 Posts
