Just wanted to get a little more info on the A/C not "returning" to the "auto" setting after entering from a remote start. I have tested this on 2 vehicles below and both worked but I have some questions.
1. 2014 Jeep Grand Cherokee Limited w/UConnect 8.4AN & 13.15.4 Feb Build
2. 2014 Jeep Grand Cherokee Summit w/UConnect 8.4AN & 13.19.0 June Build
As noted both work as I would think, I start with remote starter enter vehicle using Passive entry both vehicles the "auto" button is dimly lit until I press the start button at which time it recalls my settings.
Questions for those who have this issue so I can try and duplicate to a dealer for you:
-are you starting with the app or the remote.
-are you using passive or remote entry
-is the HVAC set to "sync" (both passenger and driver have the same temp)
-have you tried this with a short interval, say 5 minutes.
-is the power off with Engine set to 45 Seconds or a different timing.
-does your remote start cool the vehicle at all when started
-related to the above does it cool to start then stops once you enter (there seems to be two different versions of the issue and I am trying to clarify).
Thanks in advance to anyone who has this issue for detailing the experience. Not gauranteeing anything from this other than maybe to zero in on the issue if it is a setting or software.... BECAUSE I CAN'T BREAK MINE
who thought that would frustrate anyone! :slapfight:
