Status
Not open for further replies.
41 - 60 of 129 Posts
Discussion Starter #41
this may be a dumb question, being that i haven't attempted it yet, but how do you remove the stock pieces do they just pop off or unscrew? can someone shoot me a pm with a quick "how to"? thanks guys.
Discussion Starter #43
the pins unscrew, they are very tight and about 2" long. I would suggest a rag on a pair of pliers. The bevels you can carefully pry up and they will pull out with some wiggling. :thumbsup:
thats kind of what i thought, but i figured i'd ask before my set arrived and before i broke anything. thanks man, can't wait to get them installed!
you should try making some stuff for under the hood (fluid caps, etc.)
Can you tell me if you have a set available for my 2010 SRT-8. I am looking for a set of four. I have the BT Designer Series in Black Anodized and they just sit way to high. Will your pins fit thru the BT bezels? They were so tight getting on, I hope I can get them off without any marks to the door skins. Please email or pm me with your info if they are in stock so I can send you a paypal payment.
Thanks,
Terry
P.S. I am assuming you have not made these in black yet? If so, I would take a black set.
Moparpalooza Founder
2014 Durango R/T
Can you do Black?
Long Live the Grey Ghosts
Thanks,
Terry
not to butt in BUTT I had the BT also. JRs will NOT fit thru the BT bezel. JR are thicker. if you are that concerned about the door panels, take them off and remove the bezel from the inside. thats about the only way to gaurantee no peripheral damage. also i know I had to actualy make the hole bigger for the BT with a blade on one or two and those were a touch loose with JRs bezel but one wrap of black tape made it super snug. not JR faut I cut the hole for BT.
Discussion Starter #50
Thanks,
Terry
see Rob's answer below, no black just aluminum and polished alum.
Can you do Black?
no black
thanks, Rob
there dam nice
Thanks Rob for the idea. I have to get these BT's off. My elbow can't take it anymore. I will wait to here from SLVRLTNG about availabilty and payment info.
let me know when ur new sets r available!
Discussion Starter #55
I have plenty right now, just let me know if you want polished or not, thanks:thumbsup:
Discussion Starter #57
Can you contact me...I am a new member. Would like to order door pin set immediately, prefer Brushed look. I will be yet another BT convert. Thank you !!!
Discussion Starter #59
They are on the way......:thumbsup:
Status
