Status
Not open for further replies.
121 - 129 of 129 Posts
Hey af, you SRT is nasty and these door lock pins and bezels will add another 10 HP FYI.
Now is that 10rwhp per pin/bezel, or for all four??? :lol:
LOL I didn't even know these even existed until earlier today when I was doing a totally unrelated search on here. Guess I need to get on this forum more!
My locks and bezels rattle due to my knobby mud tires and the bass from my door speakers.
I was thinking about sprinkling a little Plasti-Dip inside the bezels. It's a tight fit in there so I was just thinking of only spraying just a dap.
Do any of you think that will dampen the rattle?
The only other solution would be to put the plastic bezels back in and I do not want to do that because the billet bezels look good. Damn good.
I just used a cloth and pliers for the pins and a cloth and trim removal tool for the bezels. 10 minutes and I did not have to remove the door panels.
so I twisted with channel lock pliers and the stock pin didn't seem to move and I'm afraid of damaging the mechanism in the door. Should I try heating the stock plastic pin up a bit with a heat gun? Maybe take a dremel to it and just cut through it?
Really? Wrench those bad boys. Teach them a lesson. You WK is newer than mine. I would give the pliers and or vise grips another try.
mine were a true pita to get off too you just really gotta give them hell...they will come out.
Finally got the pins in but the bezels seemed to tight so I left the stock plastic bezels in. I will post the aluminum bezels for sale on in the for sale forum.
Discussion Starter · #129 ·
did you force the bezels in? If so they will close up some. I made them a
fairly tight fit to reduce rattle. You may need to trim the panel a little. Hopefully you didn't bend the rod removing stock pins.....Jon
Status
