1 - 20 of 27 Posts
Working on some door lock pins also...Still preliminary
any way to make them lower? or does that require cutting the plunger?
I believe I can, how much lower would you like them?
Long Live the Grey Ghosts
Rob,
is that the round part pressed into the panel around the lock pin?
yes the round pressed in part?
also i would like them almost flush with the top of the door when its locked. like maybe a little nipple sticking out. but I understand you have to please the masses.
ideally, as flush with the panel as possible, at least for the front locks, I'm fine if the plunger is a bit higher in the back seat. :D
Discussion Starter · #10 ·
Rob,
I should be able to make the bezels also, I'll maybe make something up to try on Monday, time permitting......:thumbsup:
I'll see what I can do, so I guess there would be no need for the grooves since they wouldn't be visible anyway.
Banned
Jeep Grand Cherokee
DEFINITELY IN....black though!
...so I guess there would be no need for the grooves since they wouldn't be visible anyway.
correct. I prefer a silver brushed vs polished finished myself. :D
Could you do custom colors? If so I'd be in for a red one that goes flush when in.
Discussion Starter · #15 ·
Discussion Starter · #16 ·
ok. i already have bezels but it finishes it off for the rest. but I am interested in your locks as the ones I have cannot get flush as the Head of the lock is bigger than the hole in the bezels.
Discussion Starter · #18 ·
Don't know for sure if my pins will fit your bezels...Can you get me a measurement?
no then you will gaurantee it LOL.
j/k
if they dont fit when you are done, then I'll buy all of it.
Discussion Starter · #20 · (Edited)
prototype bezel and door lock:
1 - 20 of 27 Posts
