Hi All,
I'm looking for insight, input, direction regarding my Grand Cherokee Eco Diesel. I am the original owner and it has 133K miles on it. The motor blew Christmas eve night while I was headed to meet the family for church. It happened quick - like in 1/8 of a mile. Started rattling loud, engine oil light came on and then some gremlin dumped their silverware drawer into my motor. Luckily I was going downhill and I was able to coast off onto a freeway exit. As bad as it was, the situation couldn't have been any better. I live in MN, but it was a mild 44 degrees and I was only five miles from my office where I could quickly get another vehicle (unfortunately not a RAM!). Three days earlier would have sucked since I was 250 mile northwest pheasant hunting and the day finished up at 2 degrees.
It has the extended warranty due to the emissions recall and modification update it had done in 2019. So I have another 15K miles left on the warranty or another 30 months - which ever comes first. The engine light had been on for about two days and it had come on about four days prior to that for part of day, but went off. It's happened in the past and it seems to typically be an egr thing and I've cleaned the tube in the past as well.
It went to the local dealership and not surprisingly they told me it would not be covered by warranty. They could put a new motor in for $16K or give me $500.00 for the vehicle - sweet! They had removed the oil pan and "found excessive material from the main and piston rod bearings." They also found a piston rod cap bolt on the bottom of the pan. The motor was seized so they couldn't do any further testing. Hence "the X78 warranty extension does not include the engine assembly or piston rods which is the cause of failure on this engine."
I've attached the dealer report as well as the warranty extension. Any advice is greatly appreciated. And if nothing can be done, I'll probably be looking for suggestions to find a used motor. I've done a little searching. Thank you for taking the time to read this.
Steve
SRT8
I would black out our address and Phone this is the internet after all. In your PDF.
Jeep Cares first.........
