I have this in the WK section too.
I am putting together a new intake tube and I was wondering how I should terminate it inside the air box. The tube will be able to go into the air box and end above the air filter. If both ends are cut at 90 degrees, due to the bends in the tube, the short side length is 27 1/2 inches and the long side length is 32 inches. Should I leave the ends at 90 degrees or cut the end off at an angle to make both the short and long sides 27 1/2 inches, so the traveled length be the same across the tube? I looked through the hemholz resonator info online and never saw a good answer. I figure the acoustic pulse will occur around 4500 rpm during WOT., so it should be a nice boost when the power is starting to fall off.
