1 - 10 of 10 Posts
I have read the blurb in the manual and it barely makes sense to me. When I switch into tow/haul, the "D" indicator changed to "5" (almost like I and using the manumatic shifting option). Logic would tell you that selecting a lower gear number would hold you in that gear and help with descending hills.
Here's where I get confused, it specifically says in the manual NOT to use a lower gear for additional engine breaking.
Any thoughts? I understand all the stuff about disabling MDS, holding gears longer, etc. Where I get confused is when it starts talking about different gears that aren't used during normal driving mode.....
Electronic Range Select (ERS) Operation
The Electronic Range Select (ERS) shift control allows the
driver to limit the highest available gear when the shift
lever is in the DRIVE position. For example, if you shift
the transmission into 3 (third gear), the transmission will
never shift above third gear, but will shift down into
second and first gear normally.
Use of ERS (or TOW/HAUL mode) also enables an
additional underdrive gear which is not normally used
during through-gear accelerations. This additional gear
can improve vehicle performance and cooling capability
when towing a trailer on certain grades. In ERS mode,
gears 1 though 3 are underdrive gears, and ERS 4 is direct
drive. ERS 5 and 6 (Overdrive gears ) are the same as the
normal fourth and fifth gears.
You can switch between DRIVE and ERS mode at any
vehicle speed. When the shift lever is in the DRIVE
position, the transmission will operate automatically,
shifting between all available gears. Tapping the shift
lever to the left (-) will activate ERS mode, display the
current gear in the instrument cluster, and maintain that
gear as the top available gear. Once in ERS mode, tapping
the shift lever to the left (-) or right (+) will change the top
available gear.
To exit ERS mode, simply press and hold the shift lever to
the right (+) until “D” is once again displayed in the shift
lever position indicator in the instrument cluster.
Limited 4x4
I know some people turn it off while "quickly accelerating". I don't know if it makes an actual difference. I thought it simply disable overdrive -- while towing up hills, etc. I've honestly never messed with it -- when I've had it.
If you are towing a heavy load, using the Tow/Haul will direct the tranny to stay in gear longer before upshifting so as not to "lug" the engine--this give better pulling power as the lower gears are allowed to pull to high RPM before upshifting. Even if you are not towing a heavy load, 6,000+ pounds but carrying 4-5 people stuck behind an 18 wheeler or slow moving diesel pusher motorhome going 30 mph up a long steep hill, this feature will give more response and power than if the engine/trannyfrequently kicks up a gear then lugs then kicks down again.
If you also use the electronic tranny to downshift (ERS) along with Tow/Haul, it will lock the tranny to shift no higher than the selected gear, e.g., 3rd. This forces the engine to stay at higher RPMs to push more air through for better cooling and stay at peak torque band.
Gas engines have their peak torque at much higher RPMs than diesel, so using this feature is more beneficial if you are towing. Diesel engines can reach peak torque at 2,000 or lower so it can start moving the load right away instead of having to flog the squirrels to death.
Hope this helps.
So now I am completely confused, I don't have a tow /haul mode button anywhere on my dash/center counsel and I do have the 5.7 Hemi with the factory two package. So am I looking for the wrong thing? Is it a paddle switch thing + or - ERS :confused: I'm lost, and I am getting ready to pull a 6 x 12 trailer with 2 Yamaha Kodiak 700's plus extra fuel and gear. Please advise me on this situation.
2017 Summit
Read your owner's manual and stay off the internet. The OP is talking about a different model year with a different transmission.
Bill's correct about the model year/transmission. Those of us with the 6-speed have the button. Those with the 8-speed do not.
1 - 10 of 10 Posts
