2014 JGC Summit 5.7 4x4
I still have the dreaded front end "clunk" and groaning noise despite new upper control arms and new struts and new moog end links. Last time I had it in they retorqued everything and that seemed like it helped for a week. Looking at the bushings for the sway bar they look cracked to me. Can someone who has a wk2 with low miles and/or no clunk look at their bushing and see if they have the cracks you can see in the photo below. You can see the crack at the 12 o'clock and 6 o'clock positions. Or maybe that's normal.
If you are talking about the notches at 12 and 6, yes mine look the same. The picture isn't quite close enough to really see if there are any cracks but blowing it up as best as I could it looked ok. When do you hear the groan vs when do you hear the clunk?
I sometimes get groans over speed bumps. The clunks seem to be more on the drivers side over sharp bumps just for the driver side wheel. Sounds like metal to metal at it's worst.
Company I used to be EVP of produced an aerosol stop-leak AT-212 that swelled rubber seals. I've used it for years to swell up rubber bushings to try finding bad bushings in suspension parts. But it wasn't a big seller so we'd discontinued it right before we sold the company. The bottle version is ATP AT-205 stop leak, and is still on Amazon. I've never tried it on bushings but I do know that it worked well on old rubber door seals. Perhaps pouring a little into a spray bottle and spraying on bushings could help isolate the noise?? Full disclaimer- I've never tried the liquid on bushings, nor did anyone on my tech team. I still have a couple dozen aerosol cans that I'm holding onto, but maybe on ebay??
Your sway bar cases are fine. My problem with groan an clunk they were bad rack end axial rod, inner tie rod end.
After exchanging them, the sounds disappeared. Did you change them? Here picture the parts:
Related Threads
Jeep Garage - Jeep Forum
1.7M posts
176.5K members
Since 2009
