1 - 14 of 14 Posts
It is my understanding that my 2011 Overland has a fairly sophisticated oil change reminder system. Here's the deal. I bought mg GC with about 13,500 miles on the ticker. The dealer put a sticker on the windshield recommending an oil change at 18,500 mile (which I'm at now).
The oil change reminder has not popped up yet in the display. If I change the oil now it will forever be out of sync. Should I wait??
If not, is there a way reset the oil change reminder system mid-cycle?
The Negotiator
You can change oil whenever you want, you would just need to reset the oil monitor when you do it. There is a certain pattern to reset it but I don't remember it offhand. You could do a search for reset oil and find the answer.
I would say that the dealer changed the oil but did not reset the minder. Probably because it wasn't on. It's standard to change the oil on a trade before it goes on the lot. The sticker they put there sounds like the standard 5k mile change.
You can reset the minder at any time. Or so I am told, but I have yet to see proof on mine yet (haven't turned many miles since doing it).
To reset, turn the ignition "ON" but do not start the engine (KOEO key on engine off). Within 10 seconds depress the accelerator to the floor 3 times. Don't do it too fast, as it may not take. Then turn the ignition off :thumbsup:
edit: if you are doing your own changes, may I recommend the Fumoto valve. Soooo simple and so effective.
http://www.qwikvalve.com/
I'm not affiliated, just a huge fan. I have them on all the vehicles.
The Negotiator
That is the reset on some Chevy vehicles as well..
Got my oil changed and the dealer forgot to reset the oil change due light. How do I reset that on a 2014? Thanks
2017 Summit
Believe it or not,
With the Jeep in the run position but not running, step all the way down on the gas pedal three times within 5 seconds.
You no longer have to stand on one foot and rub your tummy with your left hand. :)
It is my understanding that my 2011 Overland has a fairly sophisticated oil change reminder system. Here's the deal. I bought mg GC with about 13,500 miles on the ticker. The dealer put a sticker on the windshield recommending an oil change at 18,500 mile (which I'm at now). The oil change reminder has not popped up yet in the display. If I change the oil now it will forever be out of sync. Should I wait?? If not, is there a way reset the oil change reminder system mid-cycle?
Same spot that I'm in...I had my first oil change done by the dealer, around 6,000 miles I'll say and they put the little sticker on the windshield saying next oil change at like 9,258.......I'm at 10,357, no oil indicator on yet and from what the dip stick shows the oil is good, I'm just waiting for the light to come on!
Jeep GC Limited
A bit confusing... Do I wait for the light to go on to "do" the first oil change; do I then disregard the dealer's sticker and wait for the light the next time? I know these are much the same ?'s as posted above in this thread, but still no answers....
This argument has been going on since oil change stickers, OLM's, etc., have been around. Everyone has an opinion, and your opinion may differ. The best advice I could give you is to do what makes you feel the most comfortable. If you worry about oil degrading, go with the shortest interval, if not, stretch it out. In the old days (45 years ago) we would sniff the oil on the dipstick, and if it started to smell burnt, we changed it. I've never had a problem with an engine caused by degraded oil, but that's just me. :D
I always wait for the indicator to come on, I have done this on my last three Jeeps. Manual also states up to 8000 miles between changes. Dealers always use 3000 mile interval more money in their pocket. It is not nessecary to do it every 3000 miles. The Jeep will tell when it needs it.
Same policy I follow. The dealer put the sticker on my windshield saying to bring it back after 3000 miles, but I threw that away and when I did check at 3000 miles later, I still had over 70% life left to the oil.
2017 Summit
There you go. :thumbsup:
I had my oil changed once because the Jeep was in for something else and it was free. I now have two more free oil changes that expire March 2014 and a couple more for the following year. If I used them all it would be five oil changes in two years. For me, that's three more than necessary.
If I bring the Jeep in for the recalls I'll let them change the oil. If the free changes weren't linked to my vin I would give them away.
Find out if your dip stick is ready correctly. I have a 2014 GC Summit with the 5.7 and I changed the oil and put in the recommneded 7qts. I checked the dip stick and it read 1 qt. low. I waited a couple of hours and even wiaed until the next morning and still had the same reading. I have a thread gong regarding the dip stick. if you get a chnce check your oil and let me know where its registering, then call the dealer just for the heck of it to se how much oil they actually put in.
I've also been questioning this. Manual says 8000, dealer says 3000 but my GC has the oil change indictor to inform me to change it, seems confusing. Here's a good link to some maintenance schedules,
Jeep Grand Cherokee WK2 - Maintenance information and schedules
The owner's manual gives the Maximum intervals and the dealer seems to give the minimum seeing as they want you back to see them more often. I will be changing the oil when my jeep tells me too.
So far on my third oil change my Jeep has asked for changes at 3500, 7500 and 10750.
When it comes down to it go with your personal preference, just make sure to keep an eye on your levels.
1 - 14 of 14 Posts
