Don`t know if this is a problem or not, I leave the car on auto climate, I hit the soft key to set air flow to the floor, doesn`t matter what the air temp is set at, the auto light goes out and the AC light comes on, air flow goes where I set it to go but why does the AC light go on? Dealer said they all do that, can`t find anything in the operators manual. Anyone have this issue or is this normal?
ill check in a bit when i get back to my jeep and ill let u know
Not saying its normal, but mine does the same thing.
Reactions: SteveC
· Premium Member
2018 JGC Limited
When you use "Auto" it sets the vents to blow out on the dash and top vents. When you change the fan speed or the active vents your are taking it out of "Auto" mode and are operating it "Manually". The AC light comes on because the AC was being used by the Auto operation to either cool the air (obviously) or remove moisture from the air which it will do even in colder temps to keep the dash clear of moisture.
Hope that helps...in other words, that is normal for how it is programmed.
