Started 2 nights ago. Once traveling at a decent speed 10 mph+ once I brake and come to a stop I hear a loud clunk in the front of the car. Once the car stops and does the slight roll back that's when the noise occurred. I can accelerate / turn / stop fine just this noise is occurring after braking
2005 Grand Cherokee
Sounds like a loose caliper. Either that or your sway bar links/bushings are THAT bad. Check your calipers first and ensure they're okay (as that's when you're hearing the noise), but make sure to check the bushings/links after that.
Sounds like the front differential bushings to me. I had that clunking issue during accelerating and decelerating. Also would clunk occasionally when shifting.
