Was working on my 2014 Grand Cherokee today and noticed green/fluorescent fluid in the right and left front areas of the engine compartment/radiator/condenser area.
I'm figuring this is dye in the AC refrigerant oil.
And therefore, I figure I have a leak from the condenser and it needs replacement.
Or could it be fittings/pipes leading to/from the condenser?
I'm not that familiar working on Jeeps... is this a common issue?
And how hard is to replace the condenser?
(I've done a lot of work on Audis and Porsches, so am quite handy).
Thanks! Hood Automotive lighting Automotive tire Motor vehicle Helmet
Hood Automotive tire Grey Motor vehicle Automotive exterior
Motor vehicle Hood Automotive tire Vehicle Automotive design
Hood Trunk Automotive design Vehicle Vehicle door
Grille Hood Automotive lighting Light Motor vehicle
Purple Hood Violet Gas Automotive lighting
Yes quite a common one. It's easy enough to fix this at home if you know how to hold a spanner. Get the freon removed first obvs but it's work of a couple hours to swap them out. Remember the condenser also contains gearbox oil in the top half so you'll have to replace what you remove.
Thanks.
So I understand the need to add transmission oil.
Regarding replacing the condenser, there is obviously some compressor oil in the old compressor (and I've lost some due to the leakage). Is there a recommended amount of oil that I should add to the new condenser and if so, just add it directly into the condenser?
Thanks.
Thanks.
Thanks.
yes, you need to add oil to the AC condenser, you can pour it directly into one of the fittings. The recommendation is to pour out all the existing oil into a measuring cup and add back that amount into the new condenser. My thinking is there is no way you will get all the old oil to drain out, some of it will just sit inside coating the insides so I add an additional ounce to the amount that drains out.
