OK, I've sat down and tried to juggle some numbers for cost of driving between gas and diesel so that we can actually what we gain using one engine over the other. Since I am no math whiz, please correct any flaws you see.
Let's assume gas:
3.6 should get 20 mpg on mostly hwy; 5.7 Hemi can get 18 mostly highway, and the diesel should get 27 mostly hwy.
If we also use $4.00/gallon for gas and $$.30 for diesel, we'd get
.20/mile for the 3.6
.22/mile for the 5.7
.16/mile for the diesel.
A definite savings of 6 cents per mile over the 5.7 Hemi.
However, the diesel option is $4,500 + 7.5% tax (not counting in any interest on a loan) that would make the option $4,837. A savings of 6 cents per mile will take 80,000 miles to break even.
If you tow, fuel mileage decreases and the diesel might get 20 mpg or less, but of course the diesel's better torque will make towing easier. If we
calculate towing's drain on diesel, we would also deduct the same if towing with gas. The issue is the differnece in cost as opposed to what each would cost independently.
If we also factor in DEF fluid costs, higher cost of oil changes, fuel filters, additives, the savings may be closer to 4 cents per mile difference and even more than 80,000 to break even.
Does anyone see this differently?
Let's assume gas:
