1 - 7 of 7 Posts
Here’s the problem with my ’04 Grand Cherokee SE 4.0L: About a month or so ago it started getting difficult to start. Instead of firing immediately, it would turn over half a dozen or more cranks before firing. Then last Tuesday it wouldn’t start at all. That day I replaced the plugs, checked for spark (which was good), and assumed no fuel so I changed the regulated fuel filter; started right up. Next morning, it wouldn’t start again. I discovered that after priming multiple times (can hear the fuel pump prime when the key is turned on) and turning over for about a minute or so, it would start. It would run rough for a few seconds, then idle fine. At this point let me say that it never stalled or shut off while driving, never ran rough, and showed no loss of power.
Still assuming no fuel (and doing some on-line research read that it could be the check valve in the fuel pump), I replaced the fuel pump. A very expensive proposition, as you know. It ran fine when I got it back, but the next morning it was back to the same thing; crank and crank and crank to get it started. A fuel pressure gauge on the fuel rail shows in the mid 40s for psi once primed, and bounces around 60 psi while running. Thinking a possible bad injector, I pulled the plugs again to check for a fouled plug; nothing. After replacing the plugs it started a little easier the next few times, than back to the same thing. After a few tries it sounds like it wants to fire, does that a few times, and then eventually sputters a few times, then finally actually fires and starts.
I checked my battery with a multi-meter. It was showing about 12.1 volts a few minutes after turning off. Since that is a little low and the battery was 3 ½ years old and showing a little swelling around the positive terminal. I just replaced it because I had read that Jeeps don’t like low voltage and it was on its way out anyway; still no change. Even though it doesn’t stall, run rough, or lose power, could it be the Crank Position Sensor? From what I am reading, this sensor can cause multiple problems when going bad.
Anybody have any ideas or suggestions?
· The beast from Brazil
Welcome to the garage.
The first thing which came up in my mind when reading the header was: fuel filter/regulator or o-ring in fuel pump assy. But you changed both already. Was the complete fuel pump assy replaced, or only the pump cartridge?
Did you check if fuel is coming out of the fuel rail after priming but not yet starting, just to be sure that there is not a pile of air in the line?
When you run it for a while, stop the engine and start after 10 minutes again, does it start normally or also long cranking time? Did you check the plugs after some cranking without starting to see if they are wet?
The crank sensor and cam sensor are used for fuel injection sequence and synchronizing. A bad sensor can/will prevent the engine from starting, but why would it then start after some cranking and not give problems anymore thereafter? I don�t want to say that it is not possible, but sounds strange.
I've already changed fuel filter, fuel pump, and CPS. Still no resolution to the problem and I'm into it for about $400. I should have just gone to the dealership at this point, probably. I probably have more invested than they would have charged me to repair. Of course, hindsight is 20/20.
What I observed this morning, after changing CPS last night, is the temperature gauge going to about 175 degrees as soon as I turned the key on. The outside temperature here is 23 degrees. After sitting 12 hours, the block should have been very cold.
I'm thinking that is simply the temperature sensor in the block that has gone bad and is reading too high or too low resistance, depending on what the computer is expecting to see, and the computer thinks the engine is already warm. Therefore, the computer tells the throttle body where to set the choke for proper air/fuel mix and in this case is setting it too lean.
The reason this makes sense to me is that it is always hardest to start when the engine is cold. The colder it is, the harder to start.
The question is, what kind of resistance reading should I be looking for across the temperature sensor? I’m guessing that it should have a low resistance when it’s cold, and the resistance increases as it heats up. It this assumption correct?
Any thoughts on these observations?
Of course, if I had put a multimeter across the CPS, I could have determined that there was nothing wrong with it and saved a few bucks in the process. Again with the hindsight.
This could very well be your problem. Couldn´t find any resistance values, but the sensor is a NTC type (negative temperature coefficient) The higher the temperature, the lower the resistance and the lower the temperature, the higher the resistance. You probably could check this out doing the following: disconnect the connector on the temperature sensor (on the thermostat housing) and see if it start normally now. It will most probably set the MIL light, which has to be reset afterwards. But by disconnecting it, or it will use a preset value, or it measures a high resistance (thus low temperature). If it then starts normally or at least better (depending on which temperature it uses when it is a preset value), then you have found the problem.
And the winner is, drumroll please, COOLANT TEMPERATURE SENSOR!!!
The indication from the temperature gauge (180 degrees before turning the engine over when cold) was my best clue. As Frango100 informed me, this sensor is a NTC (negative temperature coefficient) type, which means that a low temperature equals a high resistance. The ECU reads this resistance and determines from this data how much to choke the throttle body to make the fuel mix correct for the engine to start at the current temperature. My ECU was seeing that the engine was already warm, and therefore was making the mix leaner than necessary to start in the cold conditions that actually existed. The easiest way to verify this was to simply unplug the sensor, which creates an open in the circuit (this equals infinite high resistance) and telling the ECU that the engine is extremely cold. Because the ECU needs to see some resistance, even if it's very high, it sees a failure of the sensor and sets a code. The code actually read "Failed coolant temperature sensor". I cleared the code and replaced the sensor.
The resistance of the new sensor at 70 degrees F room temperature is approximately 12k Ohms.
I cannot tell you what the resistance of the old sensor is because it actually fell apart when removing it. The probe end was smashed flat and perforated. The RTD inside was exposed directly to the coolant and the contacts were corroded inside. I would like to know how the end got smashed and perforated. This should not be able to happen when installing. Even if you screw in the sensor to the bottom of the threads it should not hit anything inside the housing. I can only assume that it was damaged before it was installed, which is before I purchased the vehicle.
The temperature gauge now shows the proper reading when cold, and the jeep starts like it should.
To all who contributed ideas, thanks.
Good to hear that you have found the problem. The coolant sensor input is used for the fuel injector opening times and also for the idle air control stepper motor position. The PCM should regulate a rich mixture (via the injector opening time)and a higher idle rpm ( via the IAC position) when coolant is cold, which in your case it didn´t.
Did the engine start normally with the coolant sensor connector disconnected?
No parts of the old sensor stayed behind in the cooling system?
The engine started normally with the sensor unplugged. Set an error code because there was no sensor feedback. Although the sensor was damaged, there were no parts of it released into the cooling system. I still don't understand hoe the sensor would be damaged as it was. And more importantly, why anyone would install it like that. Thanks for all the help.
1 - 7 of 7 Posts
