1 - 20 of 87 Posts
Hi guys,
It's the second time I buy a service manual (digital edition) without succes. The last one is an htm version which is barely working. Could someone nice send me the crd section in pdf format?
I already have a fully operationnal service manual but it doesn't cover CRD.
Many thanks
Jeep Grand Cherokee
I do have a sevice manual for Grand Cherokee WK ( excluding the 3.0 CRD engine info ). Does any body know where i can get hold/buy a copy of 3.0 CRD ( WK ) Engine info ?
All help will be apreciated
Thanks
Johan
Im in the same boat. I have an electronic copy of the Service Manual but it has nothing on the CRD. I also looked in the Haynes and Chiltons manuals and saw nothing.
Did the above work for anyone. If so that is awesome and well appreciated. The only other solution that I've found is on alldata. They have a DIY section and the crd is covered. Its subscription but not all that expensive.
Here is a copy if it uploads OK. It's the 3.0l CRD section of the WK/WH manual.
"The Compressed (zipped) Folder is invalid or corrupted"
Thanks, great upload! Working excellent for me!
Hopefully I'm not gonna need it soon.. ;)
I tried it again, this time after downloading, right clicked on the file and selected "Extract", that worked.
GC/WH/OVERLAND/CRD
Hi Chris is the link to CRD manual still ok . I cannot download keeps saying file corrupt..cheers mate..Paul
after you download the file, you right-click on it and unzip. you cannot unzip the file by double clicking on it.
Reactions: rubtsov
GC/WH/OVERLAND/CRD
thanks suzieque but alas no joy here tried umteen times, it attempts to down load then flags corrupt files window.I get the file name but when I right click and select extract it says no files to extract - never mind, might try again tomorrow (if sober)but going to give it a miss for now, Happy New Year ...Paul... Liverpool UK
I also got the "corrupt file" message when I downloaded and then double clicked on the file. It was not until later that I tried right-clicking on the file and then unzipping and it worked.
Reactions: Bob Kay
1 - 20 of 87 Posts
