Yes. I wouldn't mind getting more info on some. If what we use could be replaced with something better, I would like to know.
Cheaper for us to buy in bulk since we go through so much of it.
I'm sorry guys I'm not sure how I missed this post from you. If you have any more specific questions please let me know I'd be happy to answer them. Here is some more basic information that should help you better understand the buffers. Rotary buffers are what some really high end professional detailers and body shops will often use. They offer a ton of cutting power that allows you to remove virtually any surface imperfection and a beautiful deep shine. The problem is these buffers can build up a tremendous amount of heat and potentially burn the clear coat or leave some serious holograms in the paint. If you want results nothing short of 100% perfection then get a rotary buffer and take plenty of time to master it.
For most detailers a rotary buffer is a little overkill and a little buffing power than you probably need. Local stores often have low powered random orbital buffers that just don't have enough cutting power to really be worth the investment in my opinion. My other big problems with them is that they don't often give you the ability to switch off different foam pads. Using various foam pads you can optimize the results of each step in your process. For instance the PC 7424XP can use a 4" or 6" Hook and Loop (aka Velcro) Backing Plate that screws right in. After that you can simply apply your favorite pad with ease like the blue fine finishing pad which is extremely soft and ideal for applying a sealant or wax. Using bonnets can be dangerous because of how thin they are and when dried up product builds up in them. The foam pads are 1.25" thick and again much safer to use.
The improvements of random orbital buffers have really helped weekend detailers get outstanding results without the fear of harming the finish. Random orbital buffers oscillate instead of continuously spinning in one direction like a rotary buffer does. Therefore you can not burn your paint with this buffer. It is also easy to control even at the top speed, which you control. This helps the buffer generate enough power to remove swirls, oxidation, etc. when used with a good pad and polish combination. With a buffer like the PC 7424XP you can remove roughly 75% or more of the swirls. By removing these swirls the surface will now look and feel much smoother. This allows the light to pass more directly through the clear coat and thus reflect back a deeper shine.
After you are done polishing you can use a softer pad like our blue and black pads to apply any liquid glaze, sealant or wax. This saves you plenty of time and energy so detailing can be more fun again. For more information about the buffers and how to use them please check out our Detailing Guide. If you have any other questions please let me know.
Greg @ Detailed Image
