1 - 1 of 1 Posts
I recently purchased an '08 Jeep Wrangler 4-door. I am going over the Jeep working on the things I see it needs. Some of the lamps behind the temperature controls do not work. How do I access them?
Also there are no lights on the power window switches. Is this normal and are the lamps built into the switch module?
The Jeep has a mild lift of about 2". It has spacers on the top of the rear shocks to accommodate the lift. I cannot get the bolts to budge. I even put a 3/4" impact on a lower setting. I am thinking the bolts are seized in the spacers. Any suggestions on how to free them up?
Thanks,
1 - 1 of 1 Posts
