1 - 11 of 11 Posts
My wife has stated her headlights look dimmer when she drives. Her 2013 JGC Overland has the original bulbs installed I don’t see much of a difference between them and my 2020 Ram 1500 but I do not have the D1S bulbs like the JGC. My questions:
Do the D1S bulbs degrade over time or just burn out?
Can you replace with LED based bulbs without removing the OE Ballast?
Any comments and or recommendations is appreciated.
Thank you,
Chuck
2015 WK2 Overland
HID bulbs dim overtime. I just replaced the ones in my 2015 as I was noticing they weren't as bright as when it was new. I replaced with new Osram D3S bulbs. I'm sure an LED swap would be possible but it would require rewiring.
2001 WJ/WG, 3.1TD VM Motori.
In the old days (1990!) I remember that if headlights started to become noticeably dimmer when driving, then get the serpentine belt and alternator checked as it might be the start of an alternator issue.
Any problems with other electronics playing up, bad starting, etc?
It's just a thought, as I got no idea of the tech that's put into vehicles nowadays, and it could simply be the bulbs
thank you
Did your 2015 have the D1S bulbs originally?
Finally had some time to work on this, 3 months later. Am I correct that the DRL bulbs only light up when when the projector bulbs are off, or are they supposed to help as low beams as well?
Thank you
Automotive parking light Car Vehicle Grille Automotive lighting
Automotive parking light Car Grille Automotive side marker light Vehicle
Automotive parking light Automotive tail & brake light Automotive side marker light Grille Automotive lighting
Automotive parking light Automotive side marker light Automotive tail & brake light Vehicle Grille
2018 Limited
Maybe it's just your pictures but it looks like your headlights will also be noticeably dimmer because they are no longer clear and need to be cleaned/restored.
My WJ headlamps looked misted and aged. I restored them using water, wet and dry sandpaper (800/1500/2000) and finished off with applying body wax to buff them clear. Now, whenever they look dirty, all I have to do is wash and apply the wax to rejuvenate them. Plenty of videos on You Tube on how to do this.
*Baking soda and toothpaste tactics didn't work for me.
Discussion Starter · #10 ·
Mike - I think it's just the photos, the plastic looks pretty clear, but the interior looks dusty. But I will look into the sanding and waxing.
2014 5.7 Limited ORA2
Since everyone wanted to say your lens' sucked and didn't answer your question.
When the DRL's are on (high beams at a reduced power output) the Low beam HID's are off.....only way the HID and DRL(high beams) would be on at the same time is if the headlamp switch is on and high beams are engaged
1 - 11 of 11 Posts
