1 - 6 of 6 Posts
Wk2
hi everyone
is there any way to disconnect the traction control ?
it is not good at the dunes
2017 Summit
I noticed the other day when I went into sand mode that the traction control was automatically shut off.
'14 wht/blu Overland
I don't know if it still applies to the newer jeeps, but on my WK with the transmission in park and the motor running, if you push the button it partially disables traction control (turns off some of the several acronyms that make up TC), but if you hold the button down it will ding and turn off more/all of the TC.
hi everyone
You can't disable or disconnect traction control completely. You can pull the ABS fuse, which does a bunch of things including throwing a code.... and affect braking.
1 - 6 of 6 Posts
