Purchased my new HA a few weeks ago and LOVE it. I like the sportier look, but like others I felt the forward rake and huge rear gap could be leveled out. I used the info from another forum member to make my own rear links. Super easy, super cheap, and perfect results. Not only do I feel it looks better, but I'm finding it's much easier to get in and out, loading stuff in the back is easier, and when it comes time to wash you can reach the roof easier. All that over about an inch change in rear height.
I purchased 4 8mm ball sockets from eBay user zorotools and they arrived in one day. BANSBACH EASYLIFT 96111 8mm Ball Socket 22mm M5 Thread Elbow is the name of the item. You will then need some threaded rod, but I happened to have some 10-32 bolts laying around which threaded right in. I just cut the head off and used those. You want to make the total length of the links 3.25" compared to 3.5" stock. Put all the pieces together, set to exact length and snug them up. The open ball sockets must face opposite directions which I forgot to do in my pictures. Slide under the car from behind and pop the old ones off. Replace with the new ones and you are done. NO tools required! Total cost 35 bucks! When set to 3.25" total length you will have perfectly even wheel gap between front and rear. If you want it different than that feel free to set the link length to your desire. I have not driven at night yet to see what happens to headlight cutoff, but be advised if they don't automatically adjust based on the new rear ride height you may have to lower them a bit. That's also easy and only requires a long philips screw driver. I will find out about that when I leave work tonight.
Here are the pics. Sorry the actual Jeep pics aren't great as I didn't have time for a quality shoot.
Original vs custom links. Don't forget the open side of the ball sockets will need to be turned opposite directions which I forgot to do in these pics.
Originals are 3.5" long. New ones are 3.25" for even wheel gaps.
New link installed. As easy as popping on.
Original height measured from the ground to the center of the wheel well arch in entry/exit mode (about 33.25"):
New rear height in entry/exit setting (about 32.25"):
Full shot and wheel gap shot in entry/exit height:
