1 - 20 of 88 Posts
GC Limited
This is a guide that was mostly inspired by users on a RAM forum that had luck doing this mod. Please use the information in the guide for reference. I do not take any responsibility for any damage that may occur and remember that this may not work for everyone based on various option packages. With that out of the way, on to the install guide.
This was installed on a 2014 Limited. I am not sure this work with Laredos without extra wiring as they never came with automatic headlights from the factory. On the Limited, the wiring is present.
Step 1: Order a new mirror. I used part number 68144050AD. I found mine on ebay for $51 dollars. There are plenty more around. Try to look up parts that are within your model year for this to work. A new lower mirror cover is needed, I will need to find the part number for it but it was $17.10 at the dealer.
EDIT: This might be it 1YW14DX9AC
EDIT 2: This is the one I got 68306588AA though the other part may work too.
Step 2: Remove the top cover. It is clipped into the lower cover. Spread the lower cover and it should come out with minimal resistance.
Step 3: Remove mirror and lower cover. In my case it was easier to remove the mirror and cover at the same time. Hold the mirror and cover and twist it in either direction to release. Remove the cover and cable after you remove the mirror.
Step 4: Install the new mirror. Connect the plug then place the mirror on the mount flat and turned roughly 45 degrees. Twist back into position. You can now put the new lower cover back on. The old top cover can be reused.
Step 5: Programming. I used AlfaOBD to make the changes. Connect to the BCM and make the following configuration changes:
Auto Highbeam
Select “yes”
Interior EC Mirror Present
Select“yes”
Smart Beam Present (AHBM)
Select “yes"
Auto High Beam Module Location
Select “ECC_AHBM"
Auto High Beam CSM
Select “yes”
Step 6: Reset the radio. This is not required but it will make the menu items appear immediately instead of waiting for multiple key cycles. No settings are erased in this. Be careful not to select the factory reset option.
Hold the temperature buttons for the driver side for about 10 seconds to get into the engineering menu.
Scroll until you find "Reset radio."
Select "Yes"
Step 7: Enable the Option by going to Controls > Settings > Lights. Check the "Auto Dim High Beams" option.
Step 8: All done. You will see the following in the EVIC when you flip on your high beams.
Overall a very simple install that involves replacing the rearview mirror. Make sure the area in front of the sensor is clean and clear. I had to move a car wash pass in my case as that was in the way of the sensor.
For AlfaOBD I am using the OBDLink MX Bluetooth adapter with a Surface Pro 4. There is also an Android app available.
GC Limited
Discussion Starter #6
It was a little iffy until I moved my car wash pass, not very surprising since it was in front of the camera. Working very well after moving the sticker.
Which cover did you end up using? Are the lights working as expected?
No cover -- It doesn't look too bad -- the old cover cannot be made to fit (without glue), and a new one is just not worth the money given that from the driver's seat you can barely tell the difference.
The lights appear to be working as expected.
GC Limited
Discussion Starter #12
The cover can be had for $12 or so. Worth getting to cover and protect all the wires and sensor.
Good stuff and thanks for the write up. I followed your post and added the new rearview mirror a few days ago and it seems to be working fine. Did this to MY15 limited. One thing to note was that I never found the smart beam option on my alpha odb app and also it took me a while to find each option to update. For those that are doing this, it's in the active diagnostics section under car configuration change. Then a bunch of these options come up that you have to scroll through to find.
Also I bought two mirrors before getting the one with the camera off of ebay. They didn't have great pictures of the mirror but a lot of the descriptions said they had the auto high beam feature (but they didn't). I finally ended up with the right one for about $70 but double-check it before buying. I was able to free return the ones that didn't have the camera.
Again thanks for the write up
GC Limited
Discussion Starter #15
Does anyone know if the required wiring would be present for this mod on a '18 JGC Altitude?
Is your mirror auto dimming or does it have the 911 buttons on it? If it is, then it should be good to go. All the auto dimming requires are the two can bus wires and power/ground. So if the mirror has any electronic functionality at all, the wiring should all be in place for auto high beams to work.
Mine has 3 buttons. They are as follows:
SOS - Power Button - ASSIST
I just wasn't sure since the Altitude is a Laredo if it would have the needed wiring to support the camera and the OP stated it may not work with the Laredo since this is not an option for them.
The cheapest I can currently find is $150 on eBay. If anyone has a spare for sale or knows a better place to locate one at a better price, I would try this on my '18. Hate to drop $150 not knowing if it would work or not...
GC Limited
Discussion Starter #19
Post a picture of your mirror please.
The issue may be with how the mirror dimming function would work. What stereo is installed in your Jeep?
1 - 20 of 88 Posts
