81 - 88 of 88 Posts
Hey guys! Wondering if I'd be able to do this on my '17 Altitude...the catch being that I'm putting in OEM LED assemblies which require a wiring harness (mine comes with halogen assemblies from factory and I hate the look of them, hence the pricey swap out - worth it for me though). I guess my question is whether or not the installation of a wiring harness would have any effect on doing this upgrade. You could say I don't have a mind for all these technical bits and pieces so it's a huge possibility this is a dumb question!
Otherwise, I'm pretty sure I hit all the necessary requirements as far as wiring in the mirror (auto-dimming with 911), so I would just have to purchase the factory mirror with the camera. I have the 8.4 UConnect for my radio (no nav or Apple CarPlay but I don't think that was a requirement). Thanks for any help in advance!
Sorry I can't help. Apparently mine would use a different camera then the usual photo eye behind the mirror because I have Lane sensing and ACC but if you do this let us know how it works out for you. Interested....
GC Limited
Discussion Starter #82
Make sure you note if you have the soft key in the controls section in Uconnect or if you have the physical button for mirror dimming on the mirror and buy the one that matches your set up.
Hey Roman, Ive been reading up on things...What if I find a dealer to add the sales code (LMS), which stands for auto high beams, to my vin in dealer connect? whatever that really means...
I almost stopped caring then it came back!:oops:
GC Limited
Discussion Starter #88
It’s worth a shot. They may be limited to what they can flash based on your build sheet but there is some flexibility. They also have a way of adding things to the build sheets but not all dealers will play ball on that one.
81 - 88 of 88 Posts
