1 - 9 of 9 Posts
Hi guys,
Got in the car today and as I drove off, I noticed that the e-brake light had not turned off and was flashing. Thinking I had just forgotten to take it off, I checked, but it was not engaged. So basically, it is flashing for no apparent reason. It has done this before, however rectified itself the next time I turned the car on. It's been 3 days now and it hasn't stopped. Last time, I put it down to the fact that I was pushing in the e-brake harder than normal as there was a bit of roll so I wanted to make it tighter. However, I tried to push it in not quite as far again but it is still flashing. Thoughts?
Try doing the opposite. Push the parking brake down as far as you can and releasing it a few times. Sometimes, things can bind up a bit, particularly in inclimate weather. Has worked for me every time. I never use my parking brake in the winter unless I absolutely have to.
Discussion Starter #4
Padgett: I do not have ACC
Justal: Considering I live in Australia, it isnt exactly snowing right now... but we have had a lot of rain lately, so I'll give it a go
2017 Summit
This is just a guess based on experience with some older cars. The same light that when on, solid, indicated the emergency brake was engaged, when flashing indicated a problem with the brake system.
At the very least I would say take a look at your brake fluid level.
Discussion Starter #7
padgett: it's 100% computer generated
bill: i've looked at the fluid levels, all good - i will take it to a dealer as soon as i get a chance just in case it is a major system problem
My 2012 JGC did a similar thing. The brake light stayed on and a single chime sounded. Checked the parking brake and it was released. Cycled it a couple of times and light stayed on. Not flashing but just on. Took it to dealer and they reset the light and checked fluids and a seal in the master cylinder. (TSB) They said if it happened again to call them. Went about two weeks trouble free and then it came on again for a whole day and now its off. Have a scheduled appt. to have it checked again. Frustrating.........
1 - 9 of 9 Posts
