1 - 8 of 8 Posts
I have a 2017 GC Altitude AWD 3.6L. So, the only shocks/struts it seems like you can get if you don't want to lower or raise the vehicle are Eibach E60-51-017-01-01 for the rears and the Eibach E60-51-021-02-10 / E60-51-021-03-10 for the fronts. Any other choices that anyone knows of? And anybody have the Eibach's without lowering springs or height increase that can attest to their ride/handling characteristics. My current GC has only 43K miles, and the rear shocks definitely feel shot.
Interesting . . . without looking up THAT p/n on Eibach, and no further details on your 2017 WK2, I'll add this - My Thread on the Eibach Lift/Level Kit for my 2016 (75th) V6 Trail Rated with tow Package, E80-51-021-02-22, is indicated as being Good for the 2016 & 2017 of same build (as indicated) and conventional suspension.
Spoke with Tanner @ Eibach this morning and confirmed it IS in Stock and that even THEY (at Corona Eibach) could do the install, or any # of other Dealers - most in California. Good "excuse" for a (wanted) road trip come Spring and Road & Off-Road Test the new Kit Install. Some cool #2-4 Jeep trails in all parts of California. It is a mild Springs & Shocks Kit, fore & aft. Get a Retired Military (Navy in my case) Parts Discount - from $1045 to $750.
Install (at Eibach would be $400. I'll do more research on installers come Late Winter/early Spring when I'm ready to "do it" ! Too New to have any feedback, but my gut reaction based on Their Long History and other Product reviews - all highly rated, I choose Eibach over the other limited choices . Mine is a front 2" lift & rear 0.5" lift - Leveling up the WK2 and making it more off-road worthy. More or less instilling MY mind with confidence in the vehicles ability to "perform" better in "dicy" situations; assuming all else is up to snuff; i.e. tires + !
I looked up the photos for the Eibach Shocks, even on Eibach's own website the photo of the shock does not have the tab for the swaybar end link welded on it....
But they do have different part numbers for left and right front shocks.... ....which would support they do have the tab, they need to have the tab on opposite sides of the shocks.... ...before 2016 it was one shock for both sides, just turned around, you can't do that with the tab, it has to face forward so its welded on different sides....
Thanks, again . . . I knew that, from another of your postings, but I neglected to ask ! I will call Tanner back tomorrow and Inquire about these "tabs" ! I will report back "here" after.
Did you ever find out if the tabs are on the 2016/2017 MY kit?
thanks
thanks
Sorry for the delay . . I got sick . . . wasn't doing much of anything ! But now, sadly, I still can't report anything positive . I called Tanner again and he tried to transfer me to the "design team" (his words) before it was to late (in the day) & as it turned out, it was (leave a message at the tone - I didn't). Was hoping to get back on that but as I said I got sick . I eventually emailed them - been a week now - with no response . . . frustrating, as I see they still haven't updated their webpage for the item ! I may get around to calling Tanner again, but as I said earlier, I have full confidence in the Company and see NO Reason why, to think otherwise, "tabs" or not ! ! ! WHAT THE HECK IS THE IMPORTANT SIGNIFICANCE OF THESE TABS ANYWAY ? I must of missed that along the way !
In 2016 they changed the suspension, some of the components that were steel are now aluminum....
Part of that was to switch the mounting of the front swaybar endlinks from the lower control arm that used to be steel, and switched to aluminum, so they mount the front swaybar endlinks to the tabs on the Front Shock/Struts.....
2016 and on front shocks are just like the early shocks, they just weld a tab on them to mount the swaybar endlinks on them..... ....Before 2016, there was just one front shock, you just turned it around to mount on the other side... After 2016, the tab had to be mounted on the front side, so the trick of just turning the shock around to mount on the otherside doesn't work anymore, so there are 2 part numbers for different front shocks for 2016 on...
Without the tabs, you will not be able to attach the swaybar endlinks, and very poor (even unsafe) handling especially at higher speeds could result....
Well, good timing by all, and by all I mean You, Me & Eibach ! I just got my Eibach email reply from Dave Cortez of the Design Team Dept. and to make a long effort short, the answer is YES . . . they do . I had no doubt the professionals Their would ever put out an unsafe product to the Public .
Or you may contact Dave Cortez via [email protected] to get same info. OK to reference the Forum, as I made mention of it several times, in hopes they would respond directly on the Forum .
1 - 8 of 8 Posts
