Greetings,
I have yet to come across any data on how the digital 506 watts of the Alpine Premium factory 7.1 speaker system is broken down in terms of power and the actual crossover points.
The following thread is the closet that has established the crossover points:
http://www.jeepgarage.org/f155/factory-frequency-response-55338.html
Since you have to work with 506 watts, if you want to base everything on the following assumption:
The 8 inch dual voice coil 2 ohm sub woofer has to take close to 200 watts.
The 6x9 in the front door around 75 watts.
And the rest of the 7 speakers around 30 - 35 watts.
I forgot if the 506 watt number is indeed RMS or short term (peak) musical power. It it the short term, then the RMS will be significantly less. If that is the case, then you know why this system is bad and other competing car manufactures sound better.
Unfortunately, I do not have any testing equipment left to determined the wattage coming out. For me, this does not matter, for when I do perform my upgrade, the speakers that I will be using will require some nice clean amps which I already have. This way, I can get a better sound and imagery for which a sound system should have. In all these threads all our fellow members that have replace equipment, they have constantly report greater improvement in their sound systems finally.
Best for now.
