2019 GC Trailhawk
Anyone know if there are any good areas in the firewall to pass a wire through? I have to get an antenna wire from a fender mount antenna to a fire radio. I have a 2010 GC Laredo with a V6....
Thanks
2014 SRT WK2
I piggy backed the entry point on the drivers side pretty much behind the pedals...it's a PITA on the 08+ and was prolly the hardest part of my stereo install..plus it was 2 gauge wire so yours should be easier
Jeep wk
Theres an easy spot using the hood release grommit under the steering column. Just push the wire through and it will be right there. or you can use a hole on the passenger side right near the heater tubes that goes right in behind carpet on front pasenger.
^ what he said on the hole near the heater tubes. Much easier
