1 - 16 of 16 Posts
Amber Instigator
I always hate when the time comes when you decide to rig something up on a vehicle instead of buying a totally new part. But I think this time has come for Ole Silver.I've taken it to work the last few days just so it didn't think it was gonna sit in the garage all winter salt free:lol: Well on the way home the right side turn signal started hyperflashing so I figured a bulb went out. All the bulbs were good and the problem turned out to be water got into the plug that plugs into the tail light and it is shot.The only thing working back there is my quad mod socket that doesn't use that plug. Now I just had the quarter trim off on that side and don't recall any junction handy to unplug the tail harness and maybe a few years ago I would have replaced the whole right side harness for that plug but not anymore. TBH Silver isn't new anymore and it's not worth all the cost and aggravation. Time to cut the plug off and wire up individual sockets old school like the quad mod.Probably gonna be a better deal anyway because I already had to doctor up the contacts on the tail sockets a few times. Still makes me feel crappy though.This brings up a question though. Why does the WJ use 3157's in the turns and reverse lights instead of a single filament 3156? Convenience or something more? I'm probably gonna just get 2 wire sockets for reverse and turn and run 3156's to keep things simple unless there's more to it.
2013 JKU Sahara
Aren't the turns also running lights? I'm not sure...but you're right about the reverse bulbs...not sure why they'd be 3157's.
I thought I was going to open up this thread and see that you were contemplating getting rid of it or something!
Seems like the rear light sockets on these things are notorious for sucking although I have not had any issues with mine thankfully. Some creative wiring isn't necessarily a bad thing. Sounds like you're simplifying, which is a good thing. While you're in there wire up some resistors and get your LED on already...
WJ Limited
I thought the same as Tony! While you're fixing it up, might as well put LED's in. Luckily I haven't had any issues with mine.
Amber Instigator
Good God No Man!!!! I cant believe you'd want me running around with amber on all the time back there!!! :D The fronts are though bro but not the back. Probably slipped your mind cause you have that nice tint back there and totally blocked the amber part out of your mind. Denial,it's still under there Tony..........Lurking.............:lol:.
Amber Instigator
I really want to do some tint and led's but something else always comes up. Also I'm running two extra park/stops so it's getting pretty pricey to go led back there. Someday............
2013 JKU Sahara
Ah yes...that different stripe of hideous orange. I totally forgot about that. In that case, it makes no sense to me why there would be a 2 filament bulb there. Especially in an orange bulb...because all that does is intensify the hideousness to a whole other level of brightness...hahahhaha.
Amber Instigator
Hey if you really wanted I could chop a pig tail out of my parts jeep for ya, I can sent sockets and all too assuming they are still there. Let me know
Thanks for the offer bro! Thing is those bulb contacts in the tail assy have already given me trouble before so I picked up all new sockets and am going to eliminate using them all together. I've used these for the quad tail light mod and work pretty well back there.Thanks again bud.
2013 JKU Sahara
These do work well...I believe they are for GM's. I had to splice one in up front for one of my parking lamps. I "over modified" the stock one by mistake..hehehheh
Amber Instigator
Discussion Starter · #11 ·
Yeah bro '89 to '93 GM I believe. Please elaborate on how you "over modify" a lamp socket please. You know for educational purposes:D
2013 JKU Sahara
Before I used VLED products, I had some LED wedge bulbs from another retailer. The bases were just a little too thick for the socket, so I decided to get at it with dremel. Things didnt go well...hahhahahah
I have never had any bulb problems on my or GCL, but have read of others problems.
As a precaution I picked up some sockets at a salvage yard and took them apart. I was able to solder leads on the terminals and run those leads through a hole I drilled in the back. Now if I have problems I will cut the factory wires going into the housing and connect them directly to the wires I attached on the back of the sockets.
Amber Instigator
Discussion Starter · #14 ·
That's a question I had. Does that whole socket plate unsnap from the housing? It looks like it does and would make my life a lot easier fitting the sockets.
Amber Instigator
Discussion Starter · #15 ·
With a little creative grinding on the right socket tabs on the new sockets(I understand socket "overmod" now Tony:lol:)they will twistlock just like the originals! I feel a lot better about this now and think this is the way to go if you're having tail light issues with your WJ. The socket part no. is Pico 5429PT.
Amber Instigator
Discussion Starter · #16 ·
Also on the Pico sockets concerning the turns and reverse the green wire is the bright element so that is the one you use. Either let the blue hang or cut it off. On the brake/tail of course you use both. I used 3 wire sockets on all because they are in stock everywhere and a 2 wire isn't plus a 3157 bulb will work in all of them.
1 - 16 of 16 Posts
