Have you tried disconnecting the battery and letting it sit for maybe an hour and then reconnecting? Never hurts to try a reboot.
Have you tried disconnecting the battery and letting it sit for maybe an hour and then reconnecting? Never hurts to try a reboot.I have a 2015 Cherokee Limited. Changed the battery (didn't connect a temporary power supply unfortunately) and afterwards the engine management light was lit.
I have AlfaOBD and various other OBD tools, the error won't clear. The error description is 'Implausable signal from Door Switch A (drivers side)'. Nothing seems wrong with the door functions though, all works as expected.
Also, stop/start says unavailable on the instrument panel and the Stop/Start error light is also on the dash. Car drives fine otherwise.
From searching it seems like there is a TSB for something similar and the solution is to flash the BCM with the latest firmware. Am I right in thinking only dealer can do this with WiTech? I'm in the UK so Jeeps are not common here, Alfa's and Fiat's are though. Is there any consumer software for flashing or anyone here who can flash remotely?
thanks
Ben
Tried that, thanks. Had my local mechanic look at it and he couldn't figure it out either. Have a used BCM arriving tomorrow, hopefully that will solve it - otherwise it's booked into the dealer 🙄Have you tried disconnecting the battery and letting it sit for maybe an hour and then reconnecting? Never hurts to try a reboot.
I live in North Wales, Bangor, unfortunately, there is no official Jeep dealership around here. Where have you taken your car to fix it?Got the dealer to look at and have them the info I found for a similar TSB generating error code U0216. My error code was U0516 (driver for switch).
The restored configuration of the BCM and fixed the issue, no need for any new parts.
I have the same problem...1 dealer no idea and another who won't try reset just replace ( £900). All info of where to take my Jeep greatly received.Got the dealer to look at and have them the info I found for a similar TSB generating error code U0216. My error code was U0516 (driver for switch).
To clarify my location with the Jeep is Midlands,UK. Willing and able to travel in the UK to get this resolved and the dash lights to "go away". The car is all OK otherwise.I have the same problem...1 dealer no idea and another who won't try reset just replace ( £900). All info of where to take my Jeep greatly received.
