2013 Limited 4x4 5.7
Hello everyone. I have a 2013 Limited 5.7. I just replaced the control arms and some bushings as well as put on a 2" leveling kit on. Now all of my suspension related lights are illuminated on the dash. Drove it for a but thinking the sensors needed to reset. No dice everything is still on. Not sure if a coincidence but today it felt like it was stuck in 4 low. Turned it off then back on and it seemed to shift normally. Any ideas? Thanks guys!
224278
2014 GC Limited 4X4
Sounds like broken wire to ABS sensor. Check wires routing from your wheels up the knuckles. My guess you either didn't hook back up or broke a wire. Az here also.
Thank you! What part of AZ?
