1 - 20 of 26 Posts
Altitude
Finally got around doing the gloss black SRT Taillamp bezel swamp on my 14' Altitude. I did not even realize how much better it makes the back look! Awesome. PLEASE DO NOT MIND THE DIRTY JEEP. It just rained earlier in the day and I had to get the bezels in since they were sitting on my doorstep from FedEx
2014 SRT WK2
That looks so much better! ...Pretty easy swap? My buddy wants to do this to his 14 Overland.
You should take a look at tinting the lower rear reflectors...it would finish off the rear end nicely! Here is a pic I just had mine done last week
Altitude
Yeah those gloss black bezels are nice. I don't fully understand why Jeep decided on gray bezels on the altitude which doesn't really match anything. The Altitude has gloss black everything else, why in the heck didn't they just use the same gloss black bezels as the SRT? I don't get it.
I just ordered a set of the gloss black bezels for my Summit. Can't wait to get them along with my VLED V3 Triton LED's for my rear brake lights.
Looks awesome.
I would love to swap out the useless fugly chrome ones but all the black on my ride is FLAT. How and where would I find flat black ones ...
2014 SRT WK2
How do the inner-tails come off? I removed the 2x 10mm bolts and didn't want to pull too hard as they would not come out easily...I could remove the outters with no problem. Is there a trick to remove the inner tails? Any help is greatly appreciated
2014 SRT WK2
Quick question...to install the inner bezels did you remove the inner tail lights? I took the 10mm bolts off the inners and could not get them out. Do you have to remove the rear cargo panel lining? Or do the inner bezels just pop off...any help is appreciated
The bezels are attached to the light via a single screw and 3m tape. To remove the light there are four 10mm bolts to remove per light on the lift gate. You also have to disconnect several plugs. I recommend pulling the gate liner to gain full access.
2016 High Altitude
The 3M tape is pretty sticky - You really need to pull hard and slow. I would pull and used a razor blade to cut, than pulll, than cut some tape, pull, cut, etc.
I read that the original Chrome ones you can put some black vinil i dont Know if some one has done that and looks good? Or with some rain sun etc Will look bad.. Anyone try?
Altitude
Vinyl still holding up after 4 months, easy to do.
The photo looks Nice, tell me does it look cheap? Like the 20 usd brembo calipers? You Know what i mean? Am considering doing it
Also what kind of vinil did you use?
Thanks!
Altitude
Thanks!
Sent from my iPhone using JeepGarage[/QUOTE
Good question, can you tell is 3M vinyl for $10 or $150 srt bezel, is your money your choice, here are some more pictures of my $140 saving.
Good Luck! ;)
Thanks!
Good Luck! ;)
Thanks how did you do it? Took off light took off bezel and put the 3m or just put the vinil and cut it no talking off anything?
1 - 20 of 26 Posts
