Has anyone done this on their vehicle? Im concerned that Im in way over my head to attempt this. I have the usual check engine line, generic trans code, rough shifting ect. Of course when the light is off, all shifts completely normal. Changed the TPS first with AZ parts, no fix then the more expensive MOPAR TPS. The throttle body is clean, IAC is newer, the last resort is this governor pressure sensor. So before I go out and buy the MOPAR trans fluid and a new sensor, does anyone have a word(s) of advice?
I know to drain, drop pan, remove filter, remove sensor housing, remove "transducer" the the gov press sensor. Do I need to replace the so called transducer?? Also my reverse lights do not illuminate. Where is that sensor?
Some guy in a youtube video does it and claims it should only take a half hour. Im the guy that lost his mind, spending two hours trying to remove a bolt on a mustang caliper finding out that I was turning it the wrong way. Any word of advice would be greatly appreciated. (other than "rightly-tighty, lefty loosey")
thanks for your time
