1 - 13 of 13 Posts
Boosted Turd
2010 JGC SRT8
I figured I would do a quick write up just to show how easy it really is to upgrade the look of your front end! Here is the before pic of the front
Boosted Turd
2010 JGC SRT8
Discussion Starter · #2 ·
To remove the grille insert just remove the 4 screws on top of the grille and the 3 in the front and pull the grille away from the support (just not to hard to break it) Then while holding the grille surround forward, push the grille insert back toward the support until it pops loose and then you can finagle it out.
Boosted Turd
2010 JGC SRT8
Then just slide in the grille insert you have. I bought one off ebay for around $70 and had it powder coated black for $25. There is a pic of the insert so you can see the basic size.
Boosted Turd
2010 JGC SRT8
Then just put the 4 screws back in the top. Note that i cut off the front mounting tabs to get a cleaner look once the grille is installed.
Boosted Turd
2010 JGC SRT8
And there you go, in about 15-20 min you can freshen up your front end and give a clean look!
WJ Limited
Looks good! Did you do the bottom too? I did and it makes it look even better.
Boosted Turd
2010 JGC SRT8
No i did not. Havn't had a whole lot of time lately
2013 JKU Sahara
Yeah buddy...get that lower one in too...keeps those big bugs from smashing the fins in your radiator/cooler:
Boosted Turd
2010 JGC SRT8
Discussion Starter · #9 ·
What did you guys use to hold it in place?
2013 JKU Sahara
Hubba effin' Bubba.
I was able to find a place or two to zip tie mine down. There was extra mesh too that I bent and formed around whatever was nearby to keep it from moving. It's been like that for almost a year now with no issues.
WJ Limited
You don't really need anything to hold it in place. But you can zip tie or and/or bend the mesh around whatever's close to it. I don;t have anything at all holding mine in and it doesn't move at all.
Boosted Turd
2010 JGC SRT8
Discussion Starter · #13 ·
It's a pretty easy and cheap way to make it look better. Got the insert for about $70 and powder coated for $20 (got an awesome deal) and took maybe 15 min to install
1 - 13 of 13 Posts
