Not on par with yours but spacers were a nice addition.
Excellent install. I would really suggest that you take the Amateur Radio Exam it's very easy now days.Cobra 75WX / Firestik NGP CB Install
So the next thing up on the mods list was a CB. Our club has a requirement for CB radios during group events and trail runs, and while I'm not entirely sure yet that the Grand will replace the TJ on those easier runs, it's still important for me to have it. I've been planning to take the amateur exam and eventually installing a 2m/440 system in the truck, but haven't gotten around to that yet. For now, a few miles of coms is all I need on a regular basis. For better or worse, there's not a ton of information on CB installs in the WK2 models. A handful of photos here and there of antenna mounts, and a bit of HAM installs, but I figured I'd go ahead and of a more detailed write-up for anyone else that may need it in the future.
In order to maintain a clean look for the cabin, and to occupy as little floorspace as possible, I chose the Cobra 75WX unit. The system is pretty much contained in the mic itself, with scan and weather functions, and has a separate box that converts the PL-259 coax to the mic cable, also adding an external speaker 1/8" jack (the 75WX is known for a weak speaker, since it's contained in the microphone itself... for now, it'll be fine, but I'll eventually put a speaker under one of the seats for a little more oomph). I also chose a 2' antenna with the approximate knowledge that when mounted on a spring by the bracket, I would get the top of the antenna about 8" over the roofline. While this isn't fantastic for any antenna, it will give me adequate reception and will still maintain a clean OEM+ look (it'll also be able to fit in the lower bay of my garage if ever the need arose, and I can easily swap in a taller antenna for trips with the club.
From the images I found on google, it seems most people rivet or velcro a mic clip into the center console or on either side of the 8.4" screen, but I wanted something that was a little more easily accessible and didn't require drilling a hole in the dash or the tacky look of an adhesive. I started searching for a cell phone type mount specific to the Grand Cherokee, and discovered the ProClip Console Mount which was designed to mate up to the center console by the cup holders. They provide a small tool to pop up the console and get the lip of the clip underneath for secure mounting. It took all of 2 minutes to get this thing hooked up, including drilling out and screwing in the mic clip that Cobra provided with the CB.
ProClip Mount by 2180miles
Photos of other owners who have tailgate mounted antennas on the WK2 have shown them in two locations, 1 being drilled into the brake light assembly, and the other into the lower bumper below the brake light. In both instances the antenna is mounted into plastic, so I went ahead and ordered a NGP (no ground plane) antenna from Firestik. This is a special kind of antenna where the internal wiring is designed to work at locations that do not have metal ground planes, like motorhome fiberglass, on a motorcycle where the metal is minimal, and on boats. In this instance it worked perfectly for my plastic brake light.
I initially was hesitating to drill into the brake light itself but after removing the plastic pop rivets and taking the light off the Jeep, I realized that there was plenty of room to get a metal bracket on the back side of the mount in between the tail light's plastic. I cut up a small piece (1.5" x 1.5" , if that) of 18 gauge steel to provide a firm backing to the antenna bracket. Drilling it out to the same hole pattern as the bracket I was then able to use the self-tapping screws to get through the mount, plastic brake light, and metal on the other side. I painted the metal plate and put it front of my heat gun to speed up the drying. Putting this back onto the Jeep I was able to close the tail gate and check that there were no clearance issues between the two when it closed. Initially there was a little bit of rubbing (against the tail gate side plastic, not metal thankfully!) so I took the bracket to my angle grinder with a flapper disc and smoothed it down a bit to cut down on rubbing.
WK2 Brake Light Assembly by 2180miles
WK2 Brake Light Assembly Removed by 2180miles
Firestik Antenna Bracket w/ Metal Back Plate by 2180miles
Next up in the process was figuring out how to get the coax cable back to the CB itself. I had decided from the beginning that the CB controller box would live under the battery compartment lid (the battery on the WK2 is under the passenger seat... makes 12v wiring a breeze), so the coax needed to end up there. I fed the wire through the vents in the back of the trunk, then used my interior trim tool kit to lightly bend the trim pieces and push the wiring underneath. I moved from the rear pillar to the trim piece at the very back of the trunk, then around to the passenger side. I had to unbolt the cargo tie down to lift the right side of that trim piece up, but then was able to feed the wire down along the spare tire compartment to behind the rear bench seats. Moving to the rear passenger door, I fed the coax under the door trim and then under the passenger seat bracket and into the battery compartment. It took a while to get all of this done, using patience as I was petrified of breaking a trim panel on the brand new truck, but I managed to use all 18' of the wire without any coils or major stuffing of any spare wire... all good things for signal! It's also nice that the only time the cable is exposed is the 2" between the B-pillar and the front passenger seat, and the location where it passes through the tailgate weather strip.
Once that was done, I went to check in on my buddy Rob who had been going to town with the battery compartment cover. Cobra includes a nice grommet and mount for the wire, so we decided that instead of mounting the control box on the top of the compartment cover, we'd mount it underneath. Due to where the battery lives there was a lot of room to the left side, where the control box fit perfectly. Simple crimp-on ends were easily attached to the (+) lead of the battery, and we grounded it out to the seat bracket for a good chassis ground. Drilling out the compartment cover to run the mic control cable under the seat, we then threw the grommet in there and called it good. The nice thing about this CB is that the microphone can detach from the control box so if I ever need to get it out of the way for whatever reason, it's simple to do so.
Here are the photos of the wiring (I labeled the route in red) and the under-seat bracket and wiring.
Coax Routing Through Trunk by 2180miles
Coax Through Passenger Compartment by 2180miles
Coax Into Battery Compartment by 2180miles
Batter Cover Undermount by 2180miles
Battery Cover Install by 2180miles
Battery Cover Installed- Wire Quick Disconnect by 2180miles
After this it was a matter of getting the antenna assembly onto the rear bracket, and tuning it. While Firestik tunes their CB antennas from the factory, I find it's always best to re-do the tuning on the vehicle itself to find out how the environment and install have affected its signal. The yellow band at the base of the antenna in some photos is there to denote that is is a NGP antenna and will not function normally on a standard CB antenna install. Once tightened down on the bracket and the tailgate operation was tested a few times, we took the Jeep out to the end of a state park where marshlands surround the parking lot for quite a distance in every direction. This area provides an uninterrupted surrounding for the antenna to be tuned in, not affected by power lines, buildings, or other structures that can cut down on the reception and SWR readings.
After toying around with the adjustable antenna screw for a while, Rob and I were quite pleased to have the CB measure in at around 1.2 - 1.5 SWR at channels 1, 20, and 40. In my many experiences installing CBs in my Wrangler (I've used 3, 4, and 5' antennas, so I've done a bit of tuning) and installing them in dozens of friend's rigs, this was the quickest and cleanest install to SWR readings I've ever come across. I was quite pleased. I took some photos of the Jeep while we were out there, and let Rob mess around with the air suspension, dropping it into it's lowest settings (which I hadn't yet done) and raising it up to Off-Road 2 mode, it's highest setting.
After returning back to his house, packing up my stuff and leaving, he sat in the cab of his Tacoma and we did a range-test between our radios as I drove away. I knew going into this that the 2' antenna would be a limiting factor on range, but I was happy to find that I could hear him clearly and he could receive me clearly up to around 2 miles away as the crow flies. I had measured out distances from his house online beforehand to know which landmarks marked which distances. So, a few hours and about $150 and I have a solid CB set-up in the Grand, with a range that will do just fine for what I need it for.
Hopefully this will help someone out in the future if they are doing the same thing to their WK2.
Big thanks to Rob for helping out. Here are the final photos of it installed.
WK2 Antenna Mount Bracket by 2180miles
WK2 Antenna Spring Mount by 2180miles
ProClip with CB Mic by 2180miles
Grand Cherokee CB Cabin Mount by 2180miles
WK2 Plum Island Reservation by 2180miles
WK2 Trailhawk Rear by 2180miles
WK2 Tailgate by 2180miles
This looks bad ass! Did you do the same 1.5in spacer set up as 2180? Also if you did does that or the different tire size change the speedometer? Oh and did you paint the OEM wheels all black?Not on par with yours but spacers were a nice addition.
thanks man! I actually plasti-dipped them. I did 2.5” bora spacers. And yea ive got 265/65/18s that caused the speedo to be about 2.5mph off.This looks bad ass! Did you do the same 1.5in spacer set up as 2180? Also if you did does that or the different tire size change the speedometer? Oh and did you paint the OEM wheels all black?
Yeah this is sick! I was just wondering if the tires rub in aero mode when your on the highway? I also have a grand cherokee trailhawk and am considering doing a setup similar to yours.thanks man! I actually plasti-dipped them. I did 2.5” bora spacers. And yea ive got 265/65/18s that caused the speedo to be about 2.5mph off.
Did you follow the tightening sequence and air dam placement guide in the instructions provided by Chief? I have the Bare Bones edition, and had a bit of wind noise when I first installed the rack. I have since added Malone Pro carriers using TNuts in the slots, and installed a slim light bar under the first plank......during that process I had to loosen everything and re-tighten all the planks and rails. I now have minimal wind noise at pretty much any speed. It's actually probably quieter than my OEM setup now.I just installed the Safari edition yesterday (6 planks, no surround, includes air dam) and am having significant wind noise. You can hear the rack whistling as slow as 30mph and it's noticeably louder at 60mph. It's a pretty annoying volume level so will be reaching out to Chief and hopefully they can assist.
More than likely it is the addition of the light bar underneath that reduced the noise. Maybe in concert with the canoe carriers. Even on the Chief site they say adding stuff on the rack will break up that airflow causing noise.Did you follow the tightening sequence and air dam placement guide in the instructions provided by Chief? I have the Bare Bones edition, and had a bit of wind noise when I first installed the rack. I have since added Malone Pro carriers using TNuts in the slots, and installed a slim light bar under the first plank......during that process I had to loosen everything and re-tighten all the planks and rails. I now have minimal wind noise at pretty much any speed. It's actually probably quieter than my OEM setup now.
Unfortunately...... I don't specifically know which of those things made the rack quieter. It could have been all those things combined for all I know.
I have the Offroad Animal rack, but I imagine we face some of the same issues with noise. If there is any adjustment in the front air dam, try decreasing the angle (laying it a little more flat) and raising it up from the roof surface. This made a difference on mine, and I also added a strip of edge trim to the leading side of the deflector to break up the sharp edge.More than likely it is the addition of the light bar underneath that reduced the noise. Maybe in concert with the canoe carriers. Even on the Chief site they say adding stuff on the rack will break up that airflow causing noise.
Out of curiosity, have you left the tent installed for any length of time (not to mention used)? And if so, any hint of stress on the roof? I've been digging through every article, post, and video I can find on RTTs on a WK2, and can't seem to find much on long term. I did find reference to a couple people seeing some buckling in their roof, but they didn't mention if they used a solid rack like a Chief or Gobi, or if they just stuck in on stock crossbars on the stock rails.Torro Offroad SkyLux Roof Top Tent Installation
A few months ago I was approached by Corey Johnson, founder and owner of Virginia-based Torro Offroad, about testing out their new SkyLux Roof Top Tent (hereinafter referred to as RTT). It’s always a great privilege to be able to try out products for companies, but Corey immediately was adamant about wanting transparency with my thoughts on the tent given the experience we have with our previous COE Vehicle Solutions tent. His enthusiasm for that kind of feedback made the idea of taking the SkyLux off-road and into the elements that much more exciting to me.
How has the plastidip held up for you?thanks man! I actually plasti-dipped them. I did 2.5” bora spacers. And yea ive got 265/65/18s that caused the speedo to be about 2.5mph off.
I just had my Tepui Kuekenam 3 on top of the Chief RTT edition for 3-4 months. This is with the panoramic sunroof and I see no indications of stress anywhere. Even enjoyed some off road trails at Uwharrie and the beach that shift weight significantly and no negative impact. I do think the Chief rack is a solid foundation and if you follow directions and space your cross bars correctly there will be no issue with an RTT.Out of curiosity, have you left the tent installed for any length of time (not to mention used)? And if so, any hint of stress on the roof? I've been digging through every article, post, and video I can find on RTTs on a WK2, and can't seem to find much on long term. I did find reference to a couple people seeing some buckling in their roof, but they didn't mention if they used a solid rack like a Chief or Gobi, or if they just stuck in on stock crossbars on the stock rails.
Love this - i have the same car and color.Not on par with yours but spacers were a nice addition.
Could just be the offset of the wheels, my wheels only have 8mm spacers and they're right at the fender edge, so if the wheels have a different offset it may be tucked in a little further.Those are Ridge Grapplers with 2.5 inch wheel spacers? Really not 1.5"?
Are you absolutely positive those are 2.5" spacers? The tires would be clearly outside of your wells.
Meant to ask, how do you like the tires now that its been a while? Mostly interested in snow and highway impressions. I'm looking at them for my 2020 but in a 275/65/18. Thanks in advancedTire Overhaul- Falken Wildpeak AT3W
So after a few months of behind-the-scenes work, I'm excited to announce a new partnership with Falken Tires. The WK2 will have the OEM Goodyear Adventure tires replaced with the new Wildpeak AT3W all-terrain tires. While the Grand Cherokee can actually fit a larger tire than what I went with, I wanted to keep the appearance aggressive but not overdone, so I chose the less-popular 265/65R18 size, equivalent to a 31.6" tire. It's about an inch and a half larger in diameter than the factory tire, and not only has a great aesthetic improvement for the Jeep, but also should outperform the factory tires in every regard.
I brought the Jeep to a local Firestone Tire center and for the whopping cost of $79 had the four main tires swapped, as well as the 5th OEM rim I bought back in April mounted up with the new spare and TPMS sensor. A Jeep friend bought the factory tires from me, so they're off to a new home!
Initial impressions with the AT3W are stellar... Dani and I took the Jeep up to New Hampshire for some wheeling in the woods over the weekend, got 24-25 MPG during the two hour ride up, and I know without a doubt that the Wildpeaks gave us better traction than the Goodyears ever could have on more difficult terrain than I've ever taken the Trailhawk on. I'll give a long-term review as the time comes, but for now here are some photos of the install...
New Falken Tire Delivery by 2180miles
260/60 vs 265/65 by 2180miles
Loaded Up by 2180miles
Falken AT3W Installed - 265/65R18 by 2180miles
I upsized my Trailhawk to 20 inch rims, but kept the All-Terrain Tire. I went with the Falken Wildpeak AT3W all-terrain tires.Meant to ask, how do you like the tires now that its been a while? Mostly interested in snow and highway impressions. I'm looking at them for my 2020 but in a 275/65/18. Thanks in advanced
