Not normal at all…Both Headlights on my WK2 GC have developed cracks in the lens, Jeep Dealer said only way to fix was to replace both Headlights at $4000 each (AUD) this is nuts, represents 20% of what the vehicle is worth. Does any one have any suggestions here? is this a common problem? View attachment 246635
What’s the difference between LHD and RHD headlights other than the cut off lines??Rhd ones are super rare used. It’s the same trying to get them in U.K. second hand. Weird if both sides have gone so wonder if it’s been previously tinted & overheated or as suggested above, cleaned with dodgy chemicals. Rhd AFS lights are about £800-£1000 used here so 1600-1800aud / 1000-1200usd roughly each
From what I have found out so far, this is not caused by chemicals etc, there seems to be lots of complaints world wide, my GC is in perfect condition and 'garaged'. I believe this is a 'Chrysler Jeep' problem which they are ignoring, there is definitely some problem with the plastic as the headlights age, also maybe a 'heat' problem too? Be great to get a specialist on board to investigate the problem.Not normal at all…
I’ve seen this before at work when people use the wrong chemicals to clean them.
I agree there is no way to fix them obviously. But $8,000 for a pair 😂 yea nope.. go on eBay
Even with shipping your much better off.
Mint! 14 15 16 Jeep Grand Cherokee Right Passenger RH Xenon HID Headlight OEM | eBay
Find many great new & used options and get the best deals for Mint! 14 15 16 Jeep Grand Cherokee Right Passenger RH Xenon HID Headlight OEM at the best online prices at eBay! Free shipping for many products!www.ebay.com
Yep this is how it starts, mine small cracks on LH side growing to much larger ones, the RH side was ok then but after a couple of months cracks developed here too.. As far as I am concerned this is a JEEP PROBLEM! a fault in the quality of the material used, or maybe excess heat from the headlamp.. who knowsI have a long crack in the center from top to bottom on both (identical cracks) and they have not leaked yet. If they leak I'll turn them into insurance as they were likely rock hits. But also have some other smaller cracks on both, but on the lower outside edges. Never seen plastic headlight covers crack like that.
Will need to start checking eBay out more often for good deals on used HID's.
It may be heat related…I doubt it. I think it’s an age related issue. I haven’t seen the headlights do that here in Canada. We get temp swings of -35c to 38c not sure what the climate is like where you’re at..From what I have found out so far, this is not caused by chemicals etc, there seems to be lots of complaints world wide, my GC is in perfect condition and 'garaged'. I believe this is a 'Chrysler Jeep' problem which they are ignoring, there is definitely some problem with the plastic as the headlights age, also maybe a 'heat' problem too? Be great to get a specialist on board to investigate the problem.
Thanks for the reply, I still feel that the Headlights shouldn't simply crack open, my brother has a 2004 Nissan Maxima with acrylic lenses and the headlights are fine. I live in Queensland Australia and we are in the Sub Tropics here, my Jeep GC is well cared for and garaged most of the time with 180K on the speedo. Bring back the old round glass headlights at least they lasted the life of the vehicle and you could buy them at any Auto Shop..hey.It may be heat related…I doubt it. I think it’s an age related issue. I haven’t seen the headlights do that here in Canada. We get temp swings of -35c to 38c not sure what the climate is like where you’re at..
certainly single digit percentage of Jeeps experiencing this issue.
We are talking about 9 year old headlights here… Jeep cannot be held responsible… sorry
Also nobody answered my question about differences between LHD and RHD headlights… could you not adjust the lights to suit your needs?? (See my above post)
This is also why I choose not to own European vehicles… parts and repairs are astronomical… same applies to the American vehicles as imports…. $8,000 for headlights! 😂
For fun price out BMWs new laser headlights
$20,000 for the pair !!!
BMW I12 I15 i8 Laser Headlight Retrofit OEM Headlamp Pair & Modules US Spec New
BMW I12 I15 i8 Laser Headlight Retrofit OEM Headlamp Pair & Modules US Spec New in eBay Motors, Parts & Accessories, Car & Truck Parts & Accessories, Lighting & Lamps, Headlight Assemblies | eBaywww.ebay.ca
Yep..that's how my cracks started, first the LH followed a month later by the RH one, go figureI have a long crack in the center from top to bottom on both (identical cracks) and they have not leaked yet. If they leak I'll turn them into insurance as they were likely rock hits. But also have some other smaller cracks on both, but on the lower outside edges. Never seen plastic headlight covers crack like that.
Thanks, but no chemicals used and the GC spends most of its time in an enclosed Garage, well serviced and looked after.Not normal at all…
Different shape...What’s the difference between LHD and RHD headlights other than the cut off lines??
could you not just adjust LHD cutoff line to suit??
I adjusted my WK2 HIDs and there is a surprising amount of height adjustability.
Really?Different shape...
Same as mine, no chemicals and always in the garage except when in use.Thanks, but no chemicals used and the GC spends most of its time in an enclosed Garage, well serviced and looked after.
Dont even think about buying replacement headlights in Australia - get them from the US - should be a lot cheaper and you'll probably get them quicker - I've received shock absorbers in Cairns from Michigan in 4 days (AND they cost half the Australian price - INCLUDING postage) - while the springs for the same job took nearly 3 weeks from brisbane....Both Headlights on my WK2 GC have developed cracks in the lens, Jeep Dealer said only way to fix was to replace both Headlights at $4000 each (AUD) this is nuts, represents 20% of what the vehicle is worth. Does any one have any suggestions here? is this a common problem? View attachment 246635
