New 2014 Headlights come with the Philips HIR2 9012 bulbs. Found out today. Unless you have the HID's. I have a 2014 Latitude. It has the HIR2. I upgraded the fogs to LED 5000k, sweet! they are psx24w/2504. Plug and Play.
Thanks for the info!New 2014 Headlights come with the Philips HIR2 9012 bulbs. Found out today. Unless you have the HID's. I have a 2014 Latitude. It has the HIR2. I upgraded the fogs to LED 5000k, sweet! they are psx24w/2504. Plug and Play.
I have a 2014 Cherokee Trailhawk. I see in the owner's manual it lists the fog lights as PSX24W and I just want to make sure that if I upgrade my fog lights, the ones referenced above are direct replacements and do not require any modification. They are just plug and play, correct?Correct.
You definitely want to make sure to get proper PSX24W LED bulbs for the fogs to get a true replacement.
Steve
Be careful out there. I'm a lot further out east, and I hear you got more snow and ice out there than I did here. Being in Brooklyn tomorrow is probably really gonna suck. Hope it goes smoothly for you thoughOff topic DarkHawk...but I am in Garden City today for work...off to Brooklyn tomorrow.![]()
It's odd but it started raining now and it's just really sloppy. Hoping whatever they put on the roads today will keep it from freezing. Thankfully I am not driving! Good luck, I hear more is on the way!Be careful out there. I'm a lot further out east, and I hear you got more snow and ice out there than I did here. Being in Brooklyn tomorrow is probably really gonna suck. Hope it goes smoothly for you though![]()
It's just after midnight and I just came home. Everything on the road here is frozen, so it's very slippery. Also makes it ridiculously hard to find a paring spot when they aren't all completely shoveled out. Yeah, supposed to get a lot more on Sunday.It's odd but it started raining now and it's just really sloppy. Hoping whatever they put on the roads today will keep it from freezing. Thankfully I am not driving! Good luck, I hear more is on the way!
Thats basically the same thing...the resistors are used to stop lamp out warnings and they usually call them canbus.Headlights use 9006 and there resistors NOT canbus.
I guess what I meant was, many places call their lights Canbus lights because they have a resistor in them. Thanks for that info.Actually, resistors are different from can bus - completely. Resistors simulate a 50W load and have to be used in combination with a relay harness. Canbus are capacitors which can be used with or without a relay harness.
Steve
