I have a 2011 WK2 3.6l. Just recently, I have noticed I am getting decently hot hair on the passenger side and i'm only getting warm air on the drivers side.
I need some help troubleshooting this. It doesn't appear to be a gear issue or a blend door issue, If i switch it to straight cold she runs cold. The temperature outside is -40 degrees celsius this week, I haven't had a chance to test it in warmer temperatures to see if it makes a difference.
This is what has been done/checked.
  • I have replaced both blend door gears two years ago.
  • Cabin air filter replaced.
  • Coolant flushed performed by dealer
  • Vehicle coolant temperature 88-90 degrees celsius.
Any thoughts?
Jeez -40 C is around -40 F.
Thats cold, too dam cold for me to even go out of the house.
Are you running auto climate control?
Maybe is the SYNC setting is not enabled.
