I think I have discovered another issue with my wifes grand. I discovered it when I remote started it the other day. Basically if you turn the heat all the way up, the only way to bring the temperature back down is to turn the temp to 62 degrees or lower. Has anyone else had this problem? I havent tried to see if the passenger side does it too, I have the temperatures synchronized. It wouldnt be bad except you have to do this every single time you remote start the darn thing.
