Hello,
Anyone know of any common issues on WK2 MY2011 with the heated seats?
They come on for about 10min and then shut down..
According to the manual, the first four minutes provide a boosted heat output. They are designed to stay on high for 45 minutes, then switch to the low setting for 55 minutes before shutting off.
Discussion Starter #2
So to add a little detail.. Heated seat turns on when you first start the car, heats for about 10 min and then turns off.. You cannot turn the heated seat on again until you re start up the car..
I have this issue on drivers seat, sometimes even from cold won't come on, did get a replacement heater pad on warranty a few years back but made no difference, likely wiring elsewhere. All the dealer really managed to do was damage the surface of my seat. Relatively common if you search
