First, I would be sure to pinpoint where your "noise" is coming from and describe the noise here to the other members. That way you have a better chance of not replacing parts needlessly. Case in point, I had a condition a few years back on my 2005 making a Creaking / ticking / ringing sound at the rear end while in drive. It turned out to be the U-Joint on the drive shaft in the back which in the case of the stock drive shaft cannot be replaced and required a new unit. I had visited with the local stealership and the service representative told me they had diagnosed I had a differential issue after a short drive.
The way I checked this at home was I jack up the vehicle front & rear on level ground and set it on jack stands with the tires slightly off the ground. Then I started the engine let it warm up until it reached low stable idle. Then I put in in drive, (do not accelerate at any time as you can damage your drive train), I slid underneath in back with a mechanics stethoscope and used that and my normal hearing to pinpoint the noise.
I cannot be sure that this will work for you, but it is something you can try. Good luck and keep the members updated as you find your fix. I could help someone else out.
