That’s because the bulbs were changed without removing the front fascia. I’m glad I took the time to pull mine off to change them once I seen all the little fingers that are easily bent. More than likely the other side has bent ones as well so that’s why the pattern is messed up. If you pull the front fascia off and remove the headlight assembly, I’m pretty sure they can be straightened out enough to get the bulbs seated properly. I put the Osram Cool Blue bulbs in and they are fantastic. They look like leds which is what I wanted.
