Trying to find a video on this was impossible does anyone know how or have a link that demonstrates how? Thanks.
im talking about the entire black plastic piece, i know the cutout is attached to it i just was wondering if there is a way to remove that without taking off the entire rear fasciaif your talking about the cut out,there is a template molded into the inside of the rear fascia that you follow to make the cut. It's not very difficult but you do need to stay within the lines or the trim piece will not fit correctly,.
I find it's easiest to cut with a small electric hacksaw
so you have to remove the entire bumper? you can't just take off the plastic piece like you can on the front fascia?Hey,
If I remember right when I took mine off, it's all one piece. You'll need to start at the rear wheel well area and remove the rivets and screws. Take off the tire flare/trim and then slowly pull back the fender and it all comes off. Google "WK2 rear bumper removal."
link
I don't believe you can. If I recall, when I was cutting my bottom facia out for the hitch I had the entire bumper off in one piece doing it. I did not notice anything that would separate the two apart.so you have to remove the entire bumper? you can't just take off the plastic piece like you can on the front fascia?
Ah, I guess I should read the thread title next time...im talking about the entire black plastic piece, i know the cutout is attached to it i just was wondering if there is a way to remove that without taking off the entire rear fascia
im replacing with paint matched trimYes you can remove just the black lower bumper. We did it on a neighbors 2017 Limited in order to do the cut out for a factory hitch. Didn't take long at all to unsnap it.
If you already have the tow package, why are you removing the lower black bumper?
thank you! very helpful I appreciate itAh, I guess I should read the thread title next time...
anyway, it is possible to remove the black trim without removing the whole fascia but its pretty difficult..Its only held on with clips but its pretty hard to get your hand in there to pull them off .
here is what it looks like from behind...you pop those clips out and it will come off...I think there is about 10-12 of them
great news, thank you so much!The lower part comes off pretty easily. It's just a bunch of clips. I did it when I installed the factory hitch, and it took about an hour for the whole job.
