How do you clear the low tire icon indicator?
F Fran11 · Registered Joined Aug 17, 2013 · 1 Posts Discussion Starter · #1 · Aug 18, 2013 Only show this user How do you clear the low tire icon indicator?
C cgmur · Registered Compass Joined Aug 17, 2013 · 2 Posts #2 · Aug 18, 2013 Only show this user had the same problem with a Dodge Avenger so i pumped up the tyre and all was ok
willjeep · Premium Member Joined Feb 15, 2013 · 272 Posts #3 · Aug 18, 2013 Only show this user On my 2005 G.C. right after you refilled the tire the warning went out. I read than on the 2014 you may have to drive a bit, then it resets.
O offroader · Registered Joined Aug 18, 2013 · 51 Posts #4 · Aug 18, 2013 Only show this user Drive it for 10 minutes or so. If you fixed the tire it will reset.
