1 - 20 of 32 Posts
Here is what I did and how I did it...You can obviously do it however you want as this is only how I did it and should be only used as a guide!
Parts Used:
Elite Engineering Catch Can
Elite Engineering Catch Can Bracket
7' 1/2" (13mm) Heater Hose
Hose Clamps
Bolt, Washer and Nut
Tools Used:
Allen Key
SlipJoint Pliers
HackSaw
Ratchet and Socket (Whatever size bolt you use)
Drill with Metal Bit
Ok, Lets get started...
First locate your connections...
Here is a wide shot of the area...
Now, I decided since I dont have my HUGE stock air intake anymore that I would use that space to mount my can! I just had to find how I could make it fit/work!
I decided to mount it right to the wall next to where I put the resistor for the front turn signals...
I unscrewed the resistor just to be safe...
I attached the EE bracket to the EE catch can using the supplied screws...
Next I looked for a bolt, washer and nut that would work...
Once I found one, I found a bit that would do the job and started drilling...
I unscrewed the bottom of the can, positioned it and ratcheted it on TIGHT...
I then screwed the bottom of the can back on...
Screwed the resistor back on...
I then ran to AdvancedAuto and bought a 7' piece of 1/2" (13mm) heater hose...
I measured and cut the pieces using a hacksaw and then put them on the stock fittings...
I then put them on the can fittings and clamped them down with the supplied clamps...
Here are some pics of it installed and how I ran the hoses...
And here is the finished product with the engine cover back on...
Now I know some of you have made comments about the distance and if it still can suck the stuff out...I tested it and I cant feel any diff on my thumb before/after!
Like always this is just how I did it...I take no responsibility for you!
Rock N' Roll's Sophisticate/JG Co-Founder
Charger Hellcat
Bro it looks great!
Two things:
1.) Do you think the oil will be sloshing back and forth with that long of a hose? I personally would have mounted it on the strut bar.
2.) Clean that fawking engine! :D
Bro it looks great!
Two things:
Thanks man...
As for 1) I dont think there will be enough oil to "slosh" and I didnt like the look of the strut bar mount! And 2) NEVER! LMFAO!
Frankie looks great, nice install.
Tom.
2005 Grand Cherokee
Looks nice, Like Joe, i would have mounted ti closer but it still looks good. Seems like a very easy and straight forward install for anyone.
2005 Grand Cherokee
Much better. Nice Stickers on the cover.
Banned
3 part,
1 - I like that bolt just chilling under the coolant reservoir tank where you bolt down the stock intake box. :D
2 - What's with the coolant reservoir line going over the BWoody?
3 - What's with the crankcase line (from the BWoody)? Going into the headlight? :lol:
Discussion Starter · #12 ·
3 part,
1) Dont want to lose it! ;)
2) No excuse! (Ill change it)
3) Just looks like that! :p:p
2005 Grand Cherokee
Thanks...My buddy actually airbrushed it! ;):cool:
Well damn that makes it even better.
I cant wait to remove the damn box thingy that the AFE intake i bought does not remove as part of the kit should have bought the K&N 63 series, oh well. Self owned
nice write up Frankie! We're gonna have to make a how to forum.....LOL
awesome color! LOL
where it say's lock what is that for cause i noticed the other day that mine is leaking or it overfilled?
would i be able to do this mod to a 3.7? how difficult is it? what exactly does it do, like how would it benefit the engine?
1 - 20 of 32 Posts
