how to make the "6 speed" transmission in 2012 Hemi actually work as a 6 speed?
Hi,
I have a 2012 Overland with Hemi. When I bought the vehicle, I was under the impression it was a 6-speed (as opposed to a 5-speed in MY2011). However, it seems that the transmission can't select from all 6 gears unless you manually do it yourself. The manual does state that to access all 6 gears you have to use ERS.
I find this hard to believe. And, I find it harder to believe that there's no program that allows you to have access to all 6 gears unless you manually switch the gearbox yourself and you've memorized the table that lists the gears available per mode which is documented on page 448 of the owners manual.
A few questions....:
1. for highway driving (economy at high speeds), doesn't it make more sense to be in "6" which gives you gears 1,2,4,5,6 instead of "D" which gives you 1,2,3,4,5?
2. how do you make the vehicle default to "6" which gives you gears 1,2,4,5,6? How do I make it such that the vehicle is setup to use these transmission gears without manually moving the gearbox to the right every single time I shift into D?
3. isn't it really incorrect advertising to claim it's a 6-speed transmission? 99.999% of consumers would assume that if you tell them it's a x-speed transmission it means that gears through 1-x (inclusive) are all available with the default "D" (or perhaps Sport setting, if applicable) program? It's sort of like advertising that a TV supports 1080P resolution only to find out that if your source is 1080P you have to know that ahead of time and switch the mode in the TV manually to support it which then locks out some other resolutions.
4. what is the technical reason why there's no program for the transmission that supports switching the of gears 1-6 without user intervention?
Thanks.
Hi,
Thanks.
