After reading a lot about spacers here, I asked a guy at a local shop about getting 1 inch spacers put on my Grand Cherokee. His response was that I need "hub centric wheel adapters", not spacers. Does this make any sense?
Great. Thank you.
Yes. Motorsport Tech makes custom parts and can make a wheel spacer with bolt pattern adapter and hub ring (for the wheel you want to use) on the veh you want to use it on. All three items in one unit or bolt pattern adapter/spacer in one unit, or hub ring/spacer in one unit. Your choice.After reading a lot about spacers here, I asked a guy at a local shop about getting 1 inch spacers put on my Grand Cherokee. His response was that I need "hub centric wheel adapters", not spacers. Does this make any sense?
