1 - 13 of 13 Posts
18 WK2 Trailhawk
I installed some Rigid SS-Pros in Driving Pattern, and used an old wireless controller I had installed in my last few Jeeps. The picture with the lights on outside is only the Rigids on, no other lights. I didn't adjust camera settings or anything, just too the pics with my phone. They are brighter then I expected.
220848
220849
220850
220851
220852
Reactions: Zsdebold and JCE
Trailhawk
ohhhhh... Tell me more. How do the mounts attach???How did you wire up the lights to get power??
Holy crap, I love that. I'm with @subbie09, I gotta know more.
Found the mounts.
The lights.
I want to find a lower profile light I think, but I do really like this idea. Saves me the hassle of trying to custom up a bracket for a lightbar on the roof rails.
18 WK2 Trailhawk
Discussion Starter #4
18 WK2 Trailhawk
Discussion Starter #5
I just realized that I could program the one of the homelink buttons to operate the lights. I tried it and it worked. I don't need to use the mini controller, I can just reach up and push the homelink button. I only have a single car garage so I still have one more button on my homelink if I wanted to wire something else to the controller.
Wait, what? Explain please. Are you saying you used that wireless controller and use the home link button to connect to it instead of using the remote?
18 WK2 Trailhawk
Discussion Starter #7
Yeah I saved the lighting controller radio frequency to the homelink, like you would the garage door opener and now I can open my garage door with one button on the homelink and operate the lights with another.
Reactions: BubbaATL and JCE
Genius option. That solves both my problems in the Jeep and Charger. Nice!
Reactions: Grimmjpr
18 WK2 Trailhawk
Discussion Starter #9
Glad it will help you out. I didn't know if it would work. Super excited it did.
Reactions: JCE
2018 Trailhawk
Can you share how you wired it for power? Did you wired it directly to the battery posts in the engine compartment?
18 WK2 Trailhawk
Discussion Starter #11
I wired the wireless controller, as well as the main power to the lighting relay harness to the positive terminal on the main power feed to the fuse box/TIPM, and the ground to the ground stud jump start point under the hood.
Do you have a picture of this?
18 WK2 Trailhawk
Discussion Starter #13
The first/second pic is of the engine bay and the wireless controller, the dark grey box to the left of the ECM is the wireless controller, third pic is of the positive stud the lights, and controller and the ARB compressor is wired to. The negative of the wireless controller is wired to the ground stud in pic 4 winch is wired to the ground stud in pic 4 and the main positive jump start post. The 2 small brown wires will be covered in loom once I install the Rigid Ignite back up light kit I have waiting to go in once the rear bumper and rear corner guards from Chief Products arrive. Once all that is done I'll loom everything up and set the 3rd homelink button for the backup lights. HTH
221272
221273
221274
221275
1 - 13 of 13 Posts
