1 - 12 of 12 Posts
Up till today @ 5,591 miles I have not had one hiccup on my limited, nothing at all; even the 8 speed has not been too bad. Went to come home from work and after starting the ABS light, passenger seatbelt light, traction control light, parking brake light, and check engine light ALL stayed on! Shut-off & re-started it 3 times to no avail and drove home. No speedo either in digital or circle guage, does not work, only the tachometer and turn signals seem to work. Called the dealer and cannot look at it till Wednesday morning. I thought I had a keeper!Anyone else experience this particular problem? Very heartbroken. :( Dave
2017 Summit
It's very common and no big deal. the lights will go out after a few starts with the exception of the mil ... it will take a couple more starts to go out. Everything will be working normally.
They have been aware of it for a while.
Mine happened at around 1,000 miles and they changed the pcm ... good since to 4,000 miles. For some they change the abs module.
Really, don't be too concerned.
Thanks for the info Bill, I feel better already that they will be able to deal with it. Hopefully will get the trans. flashed/updated at the same time. Thanks a lot! Dave
Lifer: Old Geezer
Overland
Some times a loose ground battery cable can do this. I would check that first. Hope I could help.
There's allegedly a cable connector down just on the passenger side of where the transmission tunnel meets the dash, and there should be a service bulletin.
When you restart, was this right away, or did you wait until every indicator including the ones for the media plugins had gone dark?
I had all of those. It was a bad ground that needed to be replaced below the TIPM on the rail.
Thanks for the replies everyone, I made some notes to give to the service manager. I am pretty sure I waited for everything to go "dark" before I re-started but no luck. I will be curious tomorrow morning when I go to work what happens. Bill De has alleviated my "un-fixable" fear!! Dave
2017 Summit
Dave,
For whatever reason, according to documentation from uConnect, the Jeep does not totally shut off until you open and close the door. This was in the instructions for doing the software updates. So, unless you opened the door, the system may not have recognized your restarting the vehicle three times as restarting the system.
Good luck in the morning.
Mine did this yesterday, :-(
There is a recall for this problem. The TSB is not released yet.
Some have had it fixed with a new ABS Unit. The Recall is using a software only fix.
Search other threads with "Xmas tree" (ss in dash board lights up like one).
1 - 12 of 12 Posts
