Have a 2007 jeep grand cherokee with the following problems.
Front windows wont do up or down
Rear tail gate will not open
Radio will not turn off with the ignition off
Power outside mirrors dont work
Replaced the BCM but still have the same problems, any suggestions?
radio could be wired incorrectly. from my experience installing radios the YELLOW wire is constant 12 volt and the RED goes to an ignition switched source. idk why some come that way. Anyone would assume that it would be the other way but just check you radios owners manual.
oops! meant to put here..
